Unread 05-09-2019, 02:49 PM   #31
Yes, it will.
Unread 05-10-2019, 08:09 AM   #32
maiyen
Would self leveling concrete not be sufficient to fix a subfloor that isn't flat and/or level?
If a mud shower floor is done, how long does it need to cure prior to tiling?
Maiyen
maiyen is offline   Reply With Quote
Unread 05-10-2019, 08:18 AM   #33
You could use a self-leveling product so long as you understand that such products do not actually self-anything. But in a small area such as you have it shouldn't be much problem to encourage it sufficiently to make the floor level and flat.
The mud bed is still the less expensive option and both corrects for the subfloor and creates the perfectly fitting sloped shower floor in one operation. The cure time is technically 20 hours, but overnight is usually adequate cure time to be able to apply your direct bonded waterproofing membrane and tile if you're in a hurry.
Need advice for shower remodel samger2 Tile Forum/Advice Board 12 06-04-2015 03:05 PM
Remodel shower, need advice Augy Tile Forum/Advice Board 6 10-27-2011 04:00 PM
Shower remodel advice ddarton Tile Forum/Advice Board 23 01-26-2009 08:41 PM
Tub/shower remodel advice Bigjohnb20 Tile Forum/Advice Board 5 08-26-2008 03:30 PM
Shower remodel advice DenCoTXPaul Tile Forum/Advice Board 12 09-17-2003 04:31 PM
