Old 06-03-2019, 08:24 AM   #31
SpaceCadet
You already tore up the floor so it's a little late but you don't have to guess about asbestos. There are labs where you can bring a sample (in person) to test for asbestos and know with a high degree of certainty. You should be able to find locations online. The place near me charged $40 per sample for overnight testing.
Also, note that one of the joists was cut pretty deep for plumbing so that one's not doing you a whole lot of good. You pretty much have a joist and a half supporting that floor. Not great (not that I'm an expert).
Paul
SpaceCadet is offline   Reply With Quote
Old 06-03-2019, 08:41 AM   #32
Elkski
Elkski's Avatar
The deflecto says 366 fir 12.5' 24" spacing , 9.25 deep 1.5 wide. Not enough for tiles. So you are going to need to beef things up. In reality your room doesn't span 12.5' and the walls actually can give the floor some rigidity but they can also be overloading the joists.
You are going to want to figure out how to beef things up. It looks like the plumber cut out way more than needed. He did try to sister it with 8" 2x4's haha. Is there a wall anywhere nearby under here? The green line? What is that covering the hole red ?.
Those electrical wires really are going to hamper things. Plus the can lights. But you have opportunity to do things right. And no handyman would tell you all this because no one would ever accept his bids.
They make toe kick saws that will cut real close to the wall. It's used under cabinets and for this type of job. Probably can rent one. Or harbor freight.
https://www.harborfreight.com/3-38-i...EaAvC6EALw_wcB
Teddy
Elkski is online now   Reply With Quote
Old 06-03-2019, 11:57 AM   #33
worldknown
The red question mark is where i almost fell through yesterday (i broke the drywall with my leg puncturing it).
Attached is a picture from the other side
worldknown is offline   Reply With Quote
Old 06-03-2019, 01:27 PM   #34
Elkski
Elkski's Avatar
I forgot to ask what is this 2x4 on my green line im my picture? Is it a wall header?
Your choices are non tile flooring or beef up that area.
Are your joist width inside or center to center?
And I ask if there are any walls below that may shorten the 12.5 length? They measure 12.5' but maybe there is a wall support below mid span or something.
Teddy
Old 06-03-2019, 02:24 PM   #35
PC7060
PC7060's Avatar
The first thing I'd address is header-ing off a access for the drain-line to address the joist Paul called out. You need to double up the joist on either side and then put a double between them.
Should look something like this when your done (hopefully without the HVAC cutting into the joist).
If you want tile, I see a future where the drywall on the level below will need to be removed to deal with these issues. I'd add another joist in the section withe CAN light while I was at it.
You'll notice the above picture is also taken from below. I had the strip off the ceiling of the dining room to get access to correct a similar set of headaches.
PC7060 is online now   Reply With Quote
Old 06-07-2019, 11:13 PM   #36
worldknown
Subfloor is put in, i sistered joists question now
Can I redgard the plywood?
I will be using ditra uncoupling membrane for the tile in the bathroom, but would like to put redgard on the plywood and around the toilet. This redgard would be underneath the uncoupling membrane and the modified thinset.
The layers would be:
1) plywood
2) redgard)
3) modified thinset
4) uncoupling membrane
5) unmodified thinset
6) tile
Would this be okay? I understand ditra is a waterproofing membrane in itself, but around the base of the toilet flange and what not i would prefer to redgard the plywood. Thank you!
Old 06-08-2019, 12:20 AM   #37
Can you? Yes.
Should you? Well, do you wear suspenders and a belt?
The only problem I see is you'll cause a bit of a hump in the area where you use Redgard, which may cause wrinkles in Ditra.
I'd give the Redgard a day or two to dry thoroughly, since it won't dry much once it's covered with Ditra.
But personally, I wouldn't do it at all.
Old 06-08-2019, 05:20 AM   #38
PC7060
PC7060's Avatar
What Kevin said. Skip the redgard.
Old 06-08-2019, 05:36 AM   #39
Elkski
Elkski's Avatar
Make sure you set your commode well. Hopefully the flange is close to level and use spacers to get it to tile height or on top. Them use a extra thick wax ring warmed to room temp. Use the plastic wedges to make sure the toilet is stable if it's not. Level tile really helps.
In the future if a toilet ever seems loose or rocks at all you must replace the toilet wax ring immediately.
You can use kerdi band on the ditra to run up the wall but keep it under the base moulding. at this stage you can make your bathroom totally waterproof except water will run out the doorway or down the heater vent. I did this one time in the kitchen because if there are any leaks I wanted the water to run out onto the cheap commercial carpet and the archery club and not get my brand new subfloor.
Teddy
Old 06-08-2019, 10:30 AM   #40
worldknown
I pretty much removed all of the black mastic by removing the subfloor, however there is one small area where the black mastic remains. And i previously used wd40 on this small spot to try and remove it. I dont want this wd40 to impact the ability for new thinset to stick to the plywood (although the actual area impacted is really small). Should i worry about this small area? If so what do you recommend i do to remove the Wd40 grease from this area?
Old 06-08-2019, 12:42 PM   #41
Elkski
Elkski's Avatar
Lunch time here. Good question.
I would have cut the new subfloor to notch in there.
Do you have any idea what your tile layout will be and where that grout line will be relative to the transition piece?
how sturdy is that little strip? And what is it sitting on ?and how sturdy is the big subfloor right there?
Did you glue the strip down?
If you put in a cross member there and glued and screwed both edges down I think ditra will be fine there.
Even if no adhesion for those few square inches.
Teddy
Old 06-08-2019, 01:24 PM   #42
worldknown
Thanks for the reply, we sistered 2x4 and 2x6's to the joists and blocked and braced the entry way. See the picture.
I'm going to have the tile run horizontal. I don't think it will be that big of a deal either because I have a laminate transition piece that will go over that spot, but if i could remove it or cover it (because of the black mastic asbestos) i would prefer to do so.
Your thoughts? I want to redgard over that area for sure to seal it in.
edit: tile will be horizontal as stated above, but wanted to clarify that it will run the same direction as the laminate in the picture. Is that a good idea?
Old 06-08-2019, 01:59 PM   #43
You're planning to use a single layer of plywood across that 26" span we see there, Mike?
And you plan no blocking under the between-joist plywood joints we see in the photo (I can't detect any T&G edge)?
What you want to do with the remaining cutback material is remove it mechanically. Your RedGard isn't likely to provide any better bond to it than would your thinset mortar. But I don't understand the application of the RedGard in that area, anyway.
Old 06-08-2019, 03:09 PM   #44
Elkski
Elkski's Avatar
You put your 2 by 6 or 2 by 4 blocking horizontal in the threshold area which is nice to tie in the old wood to the new strip but I think it would have been better structural to put a cross brace 2 x 6 vertical for strength but also sister all three or four of those joist with some cross-bracing 2,x8 or tallest you could fit. Of course you may have to notch out for those electrical wires. I see on that one side to left of door acrods from throne you have spliced two by fours so they don't maintain any rigidity Along the beam. together
Teddy
Old 06-08-2019, 03:40 PM   #45
worldknown
Underneath where the shower pan is two pieces of 3/4 plywood. Only under where the toilet and entrance is there a single layer of 3/4 plywood. This was because of the height difference would have been too dramatic with another 3/4 under the toilet area.
New Tile grout cracking jcork Tile Forum/Advice Board 2 09-06-2012 04:05 PM
New Kitchen Tile over Vinyl, tile shifting/ grout cracking cconde Tile Forum/Advice Board 17 01-03-2008 07:46 PM
Grout cracking in new tile please help? bstroman Tile Forum/Advice Board 17 04-07-2006 05:07 PM
Tile grout is cracking norah Tile Forum/Advice Board 2 01-14-2006 08:33 PM
Tile over plywood grout cracking Alex H Tile Forum/Advice Board 23 10-01-2002 05:01 PM
