Unread 05-28-2019, 06:05 PM   #91
gslenk
Second guessing the option of going with 12"x24" tile. Can't seem to get the layout looking right. The niche is off center, call it poor planning and/or stud locations.
Would it be a good idea to do all solid tiles on the 24" plumbing (left wall) or break those up every other row (or all rows)?
Should I try to line up grout lines with the niche edges? Or just let the niche fall where it may with more "centered/even" grout lines?
Here's my first instinct in 12x24 with two 3" accent tile lines. The Niche inside dimensions are 12" wide by 18" tall. Grout lines are attempted to accommodate the niche.
Lenny
gslenk is offline   Reply With Quote
Unread 05-29-2019, 01:11 PM   #92
gslenk
Turns out the best looking one I found was $5/sf, but it appears lowes sells it also, at $2.5/sf. Somehow I must have overlooked it on my initial (quick) search at lowes. Anyways... Any opinions on these manufacturers?
Winner so far: Anatolia Tile, Mayfair collection.
Marazzi Tile (runner up at the place I have been happy giving my money to)
Lastly, any thoughts on American Olean? I already used their wood look floor planks and they seem fine, and one of the mosaic options I picked for the shower floor is made by them also.
Time to work up some more grout line models to find the best looking size.
Lenny
Unread 05-30-2019, 03:02 PM   #93
I dunno, Lenny, if you'd find something suitable for $5 or less per square at the places I mentioned. I won't mention what mine was per square. Customer service was top notch though. Not that I needed any after the sale service; all my tiles have been perfect out of the box so far.
As far as brands go, I haver no idea. But what'd you'd be looking for is consistent sizing, thickness, and flatness. Should be able to get an idea of all 3 right there in the store.
Do realize though a particular tile may be advertised as, say, 12X24 it may not actually be. My wall tile was smaller, significantly, in both dimensions, which eliminated my planned layout. Yup, I over looked checking that bit before buying them.
Unread 05-30-2019, 05:57 PM   #94
makethatkerdistick
I know the surprise well that Dan described. Happened to me. The next time after that I wanted to be smarter and take actual size and thickness into account. I happened to be at "The Tile Shop". Size I could measure on their displays but not thickness, and there was no way to determine from their documentation what the thickness was. Just lots of clueless stares. I had to guess and guessed right but the interaction was painful.
I am a big fan of stores that actually let you look at and pick from their stock.
Wolfgang
Unread 05-30-2019, 06:40 PM   #95
PC7060
PC7060's Avatar
I used Anatolia tiles for both of my bathroom projects. Quite happy with the product.
Unread 05-30-2019, 10:02 PM   #96
Elkski
Elkski's Avatar
Ditto on measuring the tiles before you get to serious on layout. 12 x24" will be 11 13/16 x 23 3/4" range. So on that 24 " wet wall they may not span it. Take some spacers when you go shopping so yiu can lay out a few rows of samples amd get an accurate stack up measurement for 1 tile, 2 tiles+ 1 grout line. 3-4 tiles + grout lines. 7 p's. Proper prior planning prevents piss-poor performance. I chose dal tile over floor n decor. I have an account that gave a nice discount but main reason was quality. Im not a fan of that dot printer look. Surprising they don't use more rows of printer heads.
Teddy
Unread 06-15-2019, 09:41 AM   #97
gslenk
Yeah my plan for tile was ballpark it with some planned error margin (ie. extra inch allowance at the top/bottom rows where they meet floor/ceiling, and will be cut to size anyway), then lay the tiles on the floor and recheck my design before moving forward.
BUT... the tile is gonna have to wait. This $#%#^ outside corner is killing me. It took 3 tries (weeks) to get "strait flex tile tape" the order kept showing up as "tuff tape". Anyway, I finally got the right stuff, and while trying to sand off excess dried mud, I sanded through a corner and then proceeded to rip it all out. It came off a bit too easy for my liking, but the AP compound was still wet underneath, so probably not a real problem.
I am now thinking of using durabond or "hot mud" instead to set the corner bead. Thoughts?
For reference, this corner is outside of the shower area, and I am designing it to hopefully minimize/eliminate water migration to drywall/similar materials.
Lenny
Unread 06-15-2019, 01:22 PM   #98
Radas
Tile Newbie
Use durabond, work fast and don't worry about it being perfect. Then go over it with lightweight joint compound.
Sent from my Pixel 3 using Tapatalk
Ali
..a new excuse to hoard tools
Unread 06-15-2019, 01:32 PM   #99
makethatkerdistick
If you're going from tile to drywall, I wouldn't use the Rondec but a straight profile like "Schiene" unless you really want that exposed metal corner look. Either will work, though.
Wolfgang
Unread 06-24-2019, 10:49 AM   #100
gslenk
Wolfgang, I do like the low profile edge, however a "duller" corner seems more appropriate given how small the bathroom is and the likelihood of bumping into it.
Attached is how I envision the corner, except with brushed aluminum rondec. There will be a matching rondec for the tile to tile outside corner that is technically in the shower.
And not that I think of it, I wonder if I could shove some strong magnets inside the aluminum rondec, as a way to attach a shower curtain? hmmmm. And on that tangent, I wonder if anyone has ever embedded magnets behind tile for a similar purpose?
Lenny
Unread 06-24-2019, 11:19 AM   #101
gslenk
In a small bathroom, is it outside the realm of "normal" to tile up to the door trim? I didn't find much online. Attached is a crude example. I don't think I have room for a gap with rondec, as that would create a very small sliver of tile just outside the curb. I should be able to use a straight profile like the "Schiene" to keep the vertical tile line above the door trim clean. Door trim would be butted up against the schiene profile in this case.
Lenny
Unread 06-24-2019, 02:32 PM   #102
Lenny, you can tile up to your door casing so long as you leave a gap of at least 1/8th" and fill that gap with a flexible sealant rather than grout.
Unread 06-25-2019, 07:39 AM   #103
Concur with cx, tile right up to the casing - but strive for 1/16". To my eyes 1/8" is just too wide. I think tile+profile+casing will seem like there's too much gong on.
That's how I did my tile baseboard Lenny, right to the casing, leaving `1/16" for caulk.
Unread 06-25-2019, 10:02 AM   #104
And to my brain a 1/16th" joint is just too narrow for a flexible sealant to be effective, Dan.
Unread 06-26-2019, 06:04 AM   #105
I'll offer that since Lenny will be applying caulk between the tile and casing for only cosmetic reasons, and therefore isn't actually relying on it to seal, 1/16th" won't be an issue.
Wes's Small Bathroom Remodel wesson123970 Tile Forum/Advice Board 445 12-09-2013 07:54 AM
PK's 5x7 Small Bathroom Remodel - almost done pktaske Tile Forum/Advice Board 104 04-15-2012 11:00 AM
Jim's Small Bathroom Remodel JimInStLouis Tile Forum/Advice Board 35 05-06-2010 01:57 PM
small bathroom remodel ricky57 Tile Forum/Advice Board 16 12-07-2007 04:03 PM
Small Bathroom Remodel dcgauger Tile Forum/Advice Board 6 01-09-2004 04:26 PM
