Old 03-06-2019, 06:58 AM   #16
I agree with Lou, a surface membrane works best in this situation. The tub deck on the right side needs to be waterproof with a pitch.
Old 03-20-2019, 02:42 PM   #17
LadyA
Hi Davey,
Thanks so much for your reply. Can you explain exactly how I would do that? Would you make the pitch out of concrete and waterproof over the top?
Amanda
LadyA is offline   Reply With Quote
Old 03-20-2019, 05:19 PM   #18
rmckee84
rmckee84's Avatar
If you're asking about pitching the tub deck, that is usually done when fraiming. A suitable patching compound that can be used over your substrate could be used to create a slope as well I suppose. Then a waterproof membrane would be installed.
Ryan McKee
Old 03-20-2019, 07:16 PM   #19
I would likely notch the short studs on the tub face so the liner will set back in the notched area. Then use CBU on the tub face to the floor overlapping the liner. Get your pitch on the tub deck and cover it with a surface membrane, all the way down to the shower floor. Extra care should be taken to get a good seal against the tub.
Old 03-21-2019, 09:42 AM   #20
LadyA
Thank you so much, will work on that!
Amanda
Old 05-06-2019, 12:25 PM   #21
LadyA
Cut outs
Good morning! Iím back for more help from all of you knowledgeable people 😊
After a lot of Googling, I canít find much to help me, or I canít understand it.
1. Iím about to apply Redguard to the walls, but how do I seal the cutouts like this one?
2. Also Iím unclear on the best way to seal the gaps around the Jacuzzi tub. Before or after I Redguard?
3. One last question - thoughts on a 6x18 ceramic tile in a shower?
As usual, I appreciate all the advice 😊
Amanda
Amanda
Old 05-06-2019, 12:29 PM   #22
Tiger Mountain Tile Inc
Hi Amanda, just recently I uploaded a couple of photos that address your first question. You can find them in post #26 here.
The top photo is what would work for your situation.
Jim Upton
DIYTileGuy
Old 05-06-2019, 05:41 PM   #23
LadyA
Thank you so much, thatís a great idea!
Amanda
Old 05-06-2019, 08:11 PM   #24
LadyA
Jim, where do I find that product? Is it the same as this Kerdi one?
Amanda
South Florida shower pan. Liner or no liner satyr64 Tile Forum/Advice Board 2 12-23-2015 07:42 PM
Can copper shower pan liner 'rust through' to shower walls/floor??? claycarson Cleaning, Restoration and Sealing 8 12-12-2014 09:30 AM
First Shower Pan Liner Darren Deese Tile Forum/Advice Board 5 10-07-2009 07:49 PM
shower pan liner aliaz Tile Forum/Advice Board 33 02-02-2005 06:29 AM
shower pan liner dam Eric N. Tile Forum/Advice Board 21 01-07-2003 01:06 PM
