Unread 02-25-2019, 03:52 PM   #1
Daydo
Shower mud base/Start Floor Tiling min/max timing
Am about to do a 48" x 30" x 1.5" mud shower base over a PVC liner and pre-slope and am a bit confused regarding the following:
1. Cure time of mud base and time window for installing floor 2" x 2" mosaic tile. I found a comment from Sakcrete that says you must lay tile 16 hours after installing mud base (no more that 24 hrs.) otherwise you have to wait 28 days because it goes into a "Green" state. I actually plan on using the same mix as the pre-slope which was Quikcrete Sand/Topping Mix increased with additional sand to make it a 5:1 mix. Is this short time window correct...was hoping to have a 2-3 day window as I'm a retired DIY'r and not the fastest worker.
2. For the 1.5" final shower mud base is it advisable to install a piece of galvanized metal mesh screen in the middle for better strength. This would stop me using some 1/2" wide x 1.5" high strips of wood that I was planning on using to help me make a consistent surface thickness.
3. As you can see from the attached picture, I used a curb kit over concrete bricks for the curb. What mix should I use for this to make sure it sticks to the inside and outside surface. Should I do this first or after installing the deck surface or does it have to be done at the same time to make sure the curb and deck material bonds together with no gaps?
Any help would be gratefully appreciated.
Phil
Daydo is offline   Reply With Quote
Unread 02-25-2019, 05:02 PM   #2
1. I've never heard of that before. I guess I've been doing it wrong all these years. We've tiled immediately after placing the mud and also waited several weeks before tiling. I don't see that it matters.
2. No need for wire lath in a small shower floor like that.
3. That needs to be wall mud (fat mud) on the curb. That mix is in the liberry, about 4 sand to 1 Portland and 1 lime.
Unread 02-25-2019, 05:43 PM   #3
smifwal
concrete bags say that but you are not using a "concrete" mix since you are adding the additional sand. more sand more porous. I think... That is what I have always been told anyway
Unread 02-25-2019, 06:50 PM   #4
Daydo
Thanks for the fast replies guys.....this is a great site for knowledge transfers, especially for a DIY'r like myself.
Per your advise, Will use Quikcrete Morter mix for the curb. Is it ok to that first and then doing the base mud a couple of days later? (Remember I'm retired and not that fast)
Phil
Unread 02-25-2019, 06:51 PM   #5
Yes, That's the nice thing about cement.
Unread 02-26-2019, 02:14 PM   #6
Daydo
Fat Mud Quikrete Product Confirmation
Just want to confirm the Quikrete product shown in the attached picture is the correct "Fat Mud" product for my Kirb-Perfect shower curb as the picture is different to what is shown in Liberry post for possible products.
Phil
Unread 02-26-2019, 04:19 PM   #7
That mud will work fine.
Unread 02-28-2019, 07:03 PM   #8
Daydo
Working time for shower base mud
Ok, got the curb mudded today and next will be doing the shower base mud.
I used the handy " Deck Mud Calculator" tool....that was really handy! Looks like I will have to mix two batches which brings me to my question..... How long will I have to spread and work the mud based on a 5:1 mix.
Being on my own I will have to stop and mix the second batch and am not sure if this delay will be a problem with the first batch starting to set before I get it all troweled. ( I assume I get the perimeter done first for the height I need)
Phil
Unread 02-28-2019, 07:32 PM   #9
You might want to mix both batches up dry and set aside one until you need it. You'll have a good hour or so to get it in place. Don't mix it near as wet as you did the curb mud. The floor mud needs to be about like wet beach sand if you wanted to make a sand castle.
Unread 03-13-2019, 10:41 AM   #10
Daydo
Correct Thinset for large formal Porcelain shower wall tiles
Am finally at a point to start tiling my shower walls after building from scratch a shower base (Preslope/PVC Liner/Top Mud) and Kirb Perfect curb....it's been a long journey but this web site has been a great help for a weekend DIY'r!
I plan on using 24" x 12" x 1/4" Porcelain tiles over Durock Cement Backer Board and am confused on which type of thinset I should use...modified or unmodified?
I am also assuming I should use a 1/2" x 1/2" notched trowel and apply to walls and butter back of tile as they are so heavy.....correct?
Any guidance would be greatly appreciated plus any brands that are available from big box stores would be even more helpful.
Phil
Unread 03-13-2019, 10:53 AM   #11
Use modified. Home Depot has Custom's Prolite that works well and also Versabond LFT. Lowes has Mapei modified thinsets that will also work.
1/2 inch notch trowel is probably about right. You only need a skim coat on the tiles with the flat side of the towel if you use the notches on the wall. I would check the walls with a straight edge and get them as flat as possible. That will help you when installing those large tiles.
What are you using for waterproofing on the walls?
Unread 03-13-2019, 11:27 AM   #12
Daydo
Vapor barrier
I used a vapor barrier under the Durock so I wasn’t planning on putting anything on the top of the durock....do I need to?
Phil
Unread 03-13-2019, 11:31 AM   #13
What did you use behind the Durock? Were you able to get it out over the tub lip?
Unread 03-13-2019, 12:04 PM   #14
Daydo
I used roof tar paper and overlapped it 2” over the pvc liner material that came up 6” on the walls. I also ran a bead of silicon along the bottom of the Durock (not sure it really bridged the gap between the pvc liner and Durock that well)
Phil
Unread 03-13-2019, 12:06 PM   #15
sdiver2489
I would redgard the CB
Ryan
sdiver2489 is offline   Reply With Quote
Help please!: Timing re haze & walking on floor Paula D Tile Forum/Advice Board 14 09-03-2009 08:53 PM
Shower walls- where to start tiling? garyl53 Tile Forum/Advice Board 1 08-30-2006 11:07 AM
Tiling: Start floor or walls first? Britcheflee Tile Forum/Advice Board 2 03-29-2006 09:02 AM
About to start tiling shower, however..... Jeff L Tile Forum/Advice Board 1 03-20-2006 05:53 PM
where to start tiling floor or wall? Brian323 Tile Forum/Advice Board 3 10-13-2002 11:27 PM
