Old 02-07-2019, 10:00 AM   #1
mont2049
best tile leveling system
Good day, I am about to do a project with 7 x 36 wood look tile. I am considering using a leveling system but have never used one on my small rent house jobs. I would appreciate any advice concerning the different wedge systems. thanks
Monte
mont2049 is offline   Reply With Quote
Old 02-07-2019, 11:10 AM   #2
rmckee84
rmckee84's Avatar
Most will work, Lash is probably the cheapest and available at most HD stores. PLM and Levtec are both good but will be slightly more.
Ryan McKee
Old 02-07-2019, 07:32 PM   #3
Rigo
Rigo
These are great for a DIY'r They are made by Raimondi Leveling System
Rigo
Rigo is offline   Reply With Quote
Old 02-08-2019, 01:25 AM   #4
Topspin
SchluterUgrad
Topspin's Avatar
MLT
https://www.mltsystem.it/en/
Old 02-08-2019, 06:52 AM   #5
Though it isn't a wedge system, as a DIY'er I used Spin Doctor. More expensive but very DIY friendly. They can also be loosened and re-tightened while the mortar is still wet if you need to make adjustments.
Old 02-08-2019, 09:39 AM   #6
greenjp
Ridgid has a system that from what I can tell is nearly a copy of Spin Doctor, available at HD. 100 of the tops are $20, 100 of the bottom pieces are $10. They make a few different kinds of the latter for different joint types - linear, T, and cross shaped. I used 'em on my floor and liked them.
jeff
greenjp is offline   Reply With Quote
Old 02-08-2019, 10:22 AM   #7
mullet
mullet's Avatar
Originally Posted by Kevin
^^^this
chuck
my first Kerdi Shower
Old 02-09-2019, 03:18 PM   #8
supperfly17
Where are you guys from USA/Canada ordering the MLT from? Looks like its distributors are only in Europe.
Alex
supperfly17 is offline   Reply With Quote
Old 02-09-2019, 04:19 PM   #9
Topspin
SchluterUgrad
Topspin's Avatar
Google
mlt mechanical lippage tuning
Lots of places on line and local
https://www.masterwholesale.com/tool...ystem/mlt.html
https://www.stonetooling.com/MLT-Lev...stem-s/723.htm
https://www.contractorsdirect.com/ml...m-ready-straps
Old 02-09-2019, 04:48 PM   #10
mullet
mullet's Avatar
Plus when you get done with them, you can sell them used and get most of your money back.
chuck
Old 02-09-2019, 06:17 PM   #11
Winndustries
Alex if you find someone selling MLT in Canada let me know please.
Michael
www.winndustries.ca
Winndustries is offline   Reply With Quote
Old 02-16-2019, 07:18 AM   #12
diggerdeb
1/16 grout lines
Is there a system that will allow for 1/16 grout lines ?
Deb
diggerdeb is offline   Reply With Quote
Old 02-16-2019, 09:20 AM   #13
mullet
mullet's Avatar
Yes MLT.
chuck
Old 02-16-2019, 03:46 PM   #14
Shaklee3
I used the Progress Proleveling system, since that's what my tile shop had. It worked fine, but there are probably better ones. You do have to purchase potentially different pieces depending on what type of tile you're doing, but the top is reuseable.
Cliff
Shaklee3 is offline   Reply With Quote
Best tile leveling system mickmeyers Tile Forum/Advice Board 6 01-23-2017 09:40 AM
Tile Leveling System Just1 Tile Forum/Advice Board 5 09-20-2016 06:10 PM
Tile leveling system? slayer73 Tile Forum/Advice Board 5 05-10-2015 11:18 PM
Economical Tile Leveling System Jaxx Tile Forum/Advice Board 8 11-05-2014 04:22 AM
