Old 01-13-2019, 03:58 PM   #1
llavey
Fireplace updating
Hello everyone,
I've received some excellent guidance here in the past and am back again.
This project I am looking to resurface over a brick fireplace. When we remodeled our house, we tore it down keeping the original fireplace. The ceilings are higher now so that is the first thing that needs to be addressed. I'd also like to modernize it to fit our more transitional architecture. My first concern is if I stick ledger stone or slate tile to it do I need to worry about the added weight? I've started looking at some veneer products, but have not found any that would provide the finish I'm looking for.
Attached are a few pictures of the fireplace that show what i am working with. The fireplace is 8'6" long, 9' high and 32" wide, a sizable area compared to the small fireplace downstairs, which also used to have the same brick.
Thanks for your comments and ideas.
Link
Link
llavey is offline   Reply With Quote
Old 01-13-2019, 06:31 PM   #2
Usually adding a few hundred pounds of tile to a fireplace isn't a weight problem but with this one being upstairs it's hard to say without knowing how this fireplace is supported.
Old 01-13-2019, 07:19 PM   #3
llavey
Davy,
The fireplace passes through the first floor to the basement. I have no idea what kind of footings are under it. The house was built in the early 60ís. The ground under the house is sand. So am I catching the 1 - 2 thousand pounds of additional weight is not a big concern?
Link
Old 01-14-2019, 07:19 AM   #4
Link,
Does the basic foot print of the upstairs FP match that of the downstairs FP? And what is the downstairs FP sitting on, a slab?
Without knowing what is supporting that large column of weight I, too, would be reluctant to add significant weight to it. I think we can reasonably assume that whole column is supported by a proper foundation because, after all, it is still standing, but I'd want to know for certain.
Old 01-14-2019, 08:32 AM   #5
llavey
SS3964spd,
Yes. The footprint downstairs matches upstairs. It is sitting on the slab. I don't know if there is additional footing under the slab, or if that is even required. I did forget to mention when we rebuilt the house we raised the roof about 4 ft. That required the the chimney to be raised the same. You can see the old ceiling height by the marks on the brick in the pictures. What you can't see is the external height change which includes a going from a 4 to 6 pitch roof.
Link
Link
Old 01-14-2019, 08:52 AM   #6
Extensive work you've had done on that house, Link, including raising the chimney height. Was a structural engineer was involved?
Given the weight of all that brick, not to mention the flue, fire boxes, and the hearths, the entire column almost has to be sitting on its own foundation. If it isn't, well, I'd probably move.
Old 01-14-2019, 09:10 AM   #7
llavey
lol... Thanks.
Back when the remodel was done I didn't have the time for all this type of research. We had a very reputable General Contractor manage all the critical components to include all the engineering. They did all the tear down, rough reconstruction and completely finished the exterior. I did things like the pex heat & plumbing, finish flooring, trim and other non-structural interior work.
Link
Novice, updating basement bathroom- advice needed nesterdewalt Tile Forum/Advice Board 8 09-14-2018 11:00 AM
Cleaning and Updating Saltillo souladventurer Cleaning, Restoration and Sealing 21 03-10-2012 07:40 PM
updating shower sixtyninecobra Tile Forum/Advice Board 14 02-25-2008 11:09 AM
Updating old bathroom tile... Brian Bryant Tile Forum/Advice Board 9 01-06-2002 02:32 PM
