Unread 03-05-2010, 07:51 PM   #1
RJW
Ryan Willoughby
RJW's Avatar
floating shower walls prep ?
I was wondering how many of you guys nail your reinforcement into the studs. Whether or not you use lath or chicken wire (aka "chicken war" for you fellas from texas). I've always just used staples every 6 inches and from demoing my fair share of others 30+ year old showers, I know they ain't coming down easy. I've got an inspector that wants them nailed and was barking at me "that Marin County is the only place that doesn't prep that way". I wasn't thrilled with putting larger holes through my paper so, after locating the studs I put beads of polyurethane every 6 and sent a roofing nail through. What do you guys do?
Ryan
http://marintilestter.com
RJW is offline   Reply With Quote
Unread 03-05-2010, 08:47 PM   #2
I use roofers to fasten my lath wire to the walls. I was taught that wire must be fastened in the up direction but after mudding on my own I hang it as fast as I can I will even hang it vertically, I still prefer a ton of nails though. I like 1 1/4" roofers galvanized hot dipped.
Unread 03-05-2010, 09:01 PM   #3
RJW
Ryan Willoughby
RJW's Avatar
To make sure I'm clear, over here we screw in our 1/2 or 5/8's water-resistant gypsum backing board "green board", fire tape it, followed by a vapor barrier, wire, and then mud. No scratch coat, just 5/8 - 3/4 avg. finish coat.
Ryan
Unread 03-05-2010, 09:09 PM   #4
Chad Deiter Company
Making Cents of It All
Chad Deiter Company's Avatar
Send a message via Yahoo to Chad Deiter Company
I'm with you on that . I do a one step float too. I think most of the country still does 2 step floats. So I'm not sure if most will have any views on this . I have heard that inspectors want it nailed up though.
Chad from CDC54.com " You Dream It and We Create It "
Southern California Custom Tile and Stone Installation
Chad Deiter Company is offline   Reply With Quote
Unread 03-05-2010, 09:11 PM   #5
Used to do em like that when I was an apprentice. If your using staples to hold the wire to the drywall then you are crazy you need to fasten the wire to the studs. I would use 1 1/2" roofers in that case. I mean how long are your staples? 9/16ths?
Unread 03-05-2010, 09:20 PM   #6
RJW
Ryan Willoughby
RJW's Avatar
1/2 inch duofast every 6 inches, believe me it's not easy to rip down a wall.
Ryan
Unread 03-05-2010, 09:47 PM   #7
Chad Deiter Company
How easy is it to bend a 1/2" cement board in half ? I've torn them out many a time two and it's dang strong. When it's all mudded together and monolithic its strong.
Unread 03-05-2010, 09:54 PM   #8
RJW
Ryan Willoughby
RJW's Avatar
That's how I was taught Rick and have done 100's without having any sort of problem. That's how the majority of mud is done in the bay area, I know that. I can see that it might sound sketch if you were taught another way, but it's not. The man that taught me has been doing it like that for 40 years. Through a couple of earthquakes and still no problems. That's how I floated this beast and I guarantee it's not going anywhere.
Ryan
Unread 03-05-2010, 09:56 PM   #9
Chad Deiter Company
Damn Ryan that had to be fun to set sticks on ?
Unread 03-05-2010, 10:40 PM   #10
RJW
Ryan Willoughby
RJW's Avatar
Yeah, it was Chad. Plumbed up plastering corner profiles on those outside corners and then a few sticks Although the pics above were ply and not sheetrock.
Ryan
Unread 03-05-2010, 11:05 PM   #11
Autoplay
Tile Setter
Codes years ago in Oakland CA(could have changed since then.who knows) were 1/2"galvanized self furring lath,attached with screws EVERY 6"s or closer,on stud. Prior to floating,the lath/paper etc was inspected.
Rich
Floating shower walls start to finish mark.m@roadrunner.com Tile Forum/Advice Board 2 10-05-2008 07:42 AM
Floating shower walls mbdreaux Professionals' Hangout 6 06-05-2008 08:18 PM
floating durock walls in shower shannong Tile Forum/Advice Board 8 08-08-2005 10:30 PM
shower pan with floating walls MANewland Tile Forum/Advice Board 10 02-16-2005 12:09 PM
Shower walls -- Cement board vs "floating" installation zetta Tile Forum/Advice Board 8 09-08-2004 07:29 PM
