Unread 03-24-2018, 06:37 PM   #1
M.Audette
Seacoast Tileworks Installation Contractor
Cutting small triangles out of Marble
Hi all,
My name is Marc and I'm looking for some advise on how to cut Grecian White marble into some fairly small pointed triangles without loosing the point. This marble is pretty granular and it falls apart very easily. I'm thinking of bonding some fiberglass mesh to the back of a few tile to see if this helps. Does anyone have any tips or tricks that they've used in the past ?? I've posted a picture of the area that I'm tiling, and to make matters worst, my original plan was to create a bullnose profile on one surface, but I see no way of doing this with these small triangular pieces that I need to create.
Thanks for any help!!
Marc
Seacoast Tileworks
M.Audette is offline   Reply With Quote
Unread 03-24-2018, 06:52 PM   #2
nelsonkoehn
showers & more
nelsonkoehn's Avatar
Good blade, flat surface, steady hand.
Not sure what more to say. From what I see on your project you can do it.
Bullnose the piece first, then cut the angle
You may sacrifice a few pieces before you get it.
How many are there? Is that going up a sloped ceiling? Not quite getting the perspective. They won't all need to come to a point? Some just need an angle knocked off of a larger tile?
Nelson
tile.nkoehn.com
nelsonkoehn is offline   Reply With Quote
Unread 03-25-2018, 05:15 AM   #3
tilemanct
Tile & Stone
Sometimes I use a Glass Blade for difficult marble cuts like that. Slow as molasses but you get a 90% success rate.
CTEF Certified Installer
tilemanct is online now   Reply With Quote
Unread 03-25-2018, 05:58 AM   #4
M.Audette
Nelson,
Maybe this picture will give a better perspective . Your right in that there are only be a few that come to points, and the tile that are on the left surface are going to be just cuts, but the surface on the right, I was planning on bullnosing those tile to cap the edge.
Marc
Seacoast Tileworks
Unread 03-25-2018, 06:00 AM   #5
M.Audette
Dave,
Thanks, I have a Vetro blade that I'll try
Marc
Seacoast Tileworks
Unread 03-25-2018, 06:57 AM   #6
nelsonkoehn
showers & more
Looks like a nice project.
Yes, the wedge pieces, cut the angle on the piece plenty long. Then bullnose it. The cut off the back edge, the square cut, to get it to fit.
Slow and steady!
Nelson
tile.nkoehn.com
Unread 03-26-2018, 06:50 AM   #7
Hi Marc,
I think you should just abandon that project. It can't be done.
Naw, what the others said.
Unread 03-26-2018, 05:18 PM   #8
I guess you know the joints won't line up on the two walls. Not much you can do about it without a lot of cutting.
Unread 03-30-2018, 07:54 AM   #9
M.Audette
Well except for the tiny microscopic pieces left, most of the wall is laid. The advice to bullnose first then cut with a glass blade proved to be the answer. Thanks to all that chimed in.
Marc
Seacoast Tileworks
cutting small hex tiles TilingSam Tile Forum/Advice Board 11 02-25-2017 12:35 AM
Combing thinset into triangles of diagonal layouts firedwet Tile Forum/Advice Board 3 11-13-2013 01:08 AM
cutting small slate tiles Cathy Tile Forum/Advice Board 5 11-17-2006 07:18 PM
Cutting small tiles with backing eburr Tile Forum/Advice Board 18 05-18-2006 03:37 PM
