Unread 05-27-2013, 05:15 PM   #1
Kilauea
LT
Kilauea's Avatar
Custom Shelves
Ive been trying to get new ideas for shelves.Ive gotten alot of ideas from this forum but the pics ares scattered on different threads.Rod has a cool one on the "Bench" thread,and alot of them are on the "Progress" thread.
Most of my shelves are made with my wet polisher,but it had been in NJ getting fixed and I had to come up with a quick solution.
Here is what I came up with-
1.Two triangular pieces with the front edge mitered.
2.The bottom piece sticks in like how you would normally notch it,with the bottom facing upward.
3.The next piece (not notched,of course) goes directly on top
4.Lastly,a sliver the width of the two tiles gets mitered on both sides and goes on the front,and also needs a miter on each end two fit tight against the wall.
I used the Dewalt with Razor to cut this with,extremely accurate combo .I was pretty excited when it worked.
Here are some pics-
*L.T.*
tandctile-dot-net
2nd generation tile installer
Kilauea is offline   Reply With Quote
Unread 05-27-2013, 05:22 PM   #2
Kilauea
LT
Kilauea's Avatar
It just so happened that my next project happened to be an app with multicolored slate.We all know how pretty the surface can be,but not so much the body.This help to give it an illusian of thru body color......
*L.T.*
tandctile-dot-net
Unread 05-27-2013, 06:46 PM   #3
HS345
Tile Contractor
HS345's Avatar
Wow, very cool solution L.T.
Luckily for me, my local supplier carries a wide variety of stone shelves.
The name's Greg
Unread 05-27-2013, 07:24 PM   #4
gueuzeman
Keeping the tile glaze as the exposed surface is in some ways better than the polisher exposing the porcelain body.
DeWalt saw to the rescue!!!
great post, L.T.!!
gueuzeman is offline   Reply With Quote
Unread 05-27-2013, 07:46 PM   #5
Kilauea
LT
Kilauea's Avatar
Thanks,guys.Hopefully this will encourage all of u to post some custom shelves!Thanks IA
*L.T.*
tandctile-dot-net
Unread 05-27-2013, 07:55 PM   #6
evan1968
Not So Senior Contributor
evan1968's Avatar
That's the sizzle LT...nice job!
Craig
Commercial Tile Installations
KEEP CALM and TILE ON
Unread 05-27-2013, 08:32 PM   #7
josephlewis
I made these last week. Customer wanted the accent tile as the front of the shelves.
Joseph
www.LewisRenovation.com
Round Rock, TX
josephlewis is offline   Reply With Quote
Unread 05-27-2013, 09:07 PM   #8
Kilauea
LT
Kilauea's Avatar
Wow.Right off the bat.
Killer shelf,bro!
*L.T.*
tandctile-dot-net
Unread 05-27-2013, 09:32 PM   #9
jwmezzanotte
jwmezzanotte's Avatar
LT
I have built quite a few of those, and posted pictures (you areright, all over the place. This thread is a great Idea!)
The only thing I do differently is sandwich a third piece of tile in the center to thicken it up a bit.
Heres a niche with shelves I did recently.
Unread 05-27-2013, 09:40 PM   #10
jwmezzanotte
And on a job last year, I forgot ( ) to install the corner shelves that the customer had asked for.
Made these up with stainless steel "biscuits" (washers) to install in the grout lines after the shower was finished. I cant claim that idea, stole it here on this forum somewhere.
Great idea though as an option for adding shelves later.
Unread 05-27-2013, 10:00 PM   #11
Kilauea
LT
Kilauea's Avatar
Wow,even more than th 1st wow!
See,this just goes to show how much great minds think alike.Very much liike the clovis point!
*L.T.*
tandctile-dot-net
Unread 05-27-2013, 10:17 PM   #12
TileArt1
TileArt1's Avatar
Used the upside-down triangle as the base with one piece of the glass liner across the front, bullnose on top with fill-in triangle in the back. Continued the glass one from each wall to continue the pattern.
Roger (The FloorElf)
Unread 05-27-2013, 10:53 PM   #13
PetrH
for me it's definitely solid rock or nothing. I pick up free scraps from counter top manufacturers and shape them. Mostly I try to get the softer rocks like Marble, Limestone, and travertine. The hole holds a razor.http://www.johnbridge.com/vbulletin/...1&d=1369716802
Petr
Unread 05-27-2013, 10:54 PM   #14
Hank B.
Some shelves
Hank
Hank B. is offline   Reply With Quote
Unread 05-27-2013, 11:01 PM   #15
jwmezzanotte
Petr,
I like that also. Sink cutouts are gold for me. I'll hoard them whenever I get the chance. Although that doesn't happen often around here. Shipping to the middle of nowhere for slabs is killer!
Btw, I like the razor holder. May steal that one day
Sometimes though, I like the look of using the field tile to have a shelf blend in. Cant wait to do a couple with my dewalt Using my old mk 370 for that was tough..
custom levelquick over custom peel and stick membrane Big Joe Tile Forum/Advice Board 7 12-15-2012 10:17 AM
Custom Building Products Custom Blend CharlesW Tile Forum/Advice Board 15 02-20-2009 11:51 AM
Building Custom Shelves/Benches MNTileGuy Professionals' Hangout 9 10-15-2008 08:20 PM
Custom Niche Shelves mrbreakit Tile Forum/Advice Board 2 03-19-2008 08:49 PM
custom shelves RedRock Professionals' Hangout 3 08-30-2007 09:52 AM
