Unread 06-04-2014, 04:17 PM   #31
Jim Cordes
Thats not scrap thats gold. You are going back to try to pick it up right?
Jim
Jim Cordes is offline   Reply With Quote
Unread 06-04-2014, 05:35 PM   #32
Giuseppex
^ I agree. Could make some fun stuff with that.
Giuseppe
Giuseppex is offline   Reply With Quote
Unread 06-06-2014, 12:23 PM   #33
RipRap
Originally Posted by Jim Cordes
Love what you guys are doing with this foam, How does 3lb compare to a kerdi pan for hardness to give me an idea?
I measured some of the 25psi foam I used and it seemed to be in the 1.5lb range.
Schluter says their foam is around 50psi, so my guess would be that the 3lb stuff may be similar.
Your could make a test by setting a large marble or cone on a schluter scrap weighed down by a weight - measure the dent, do the same on your new material for a simple comparison.
RipRap is offline   Reply With Quote
Unread 06-07-2014, 08:33 AM   #34
Jim Cordes
Great thx Kevin, will be doing a test soon.
Jim
Unread 06-07-2014, 03:38 PM   #35
Katwyk tile
Some at home testing I have been doing over the last month.
I cut the bottom out of this solo cup and siliconed it to a piece of 1/4" thick 3lb expanded polystyrene. I filled the cup up with colored water and let it sit for over a month. No water appeared to come through.
What does this test prove I really don't know. I would not use the phone with out putting on a waterproof membrane when it came to shower walls benches or floors. I also have been putting a piece of foam that is connected to a piece of porcelain in and out of the freezer while soaking it also with water just to see if I get any kind of separation.
Katwyk tile is offline   Reply With Quote
Unread 06-07-2014, 03:41 PM   #36
Katwyk tile
After one month it apears no water made it through .
Unread 06-07-2014, 03:43 PM   #37
Katwyk tile
I cut the test piece in half and did notice some red color that had gone into the foam
Unread 04-25-2015, 06:42 PM   #38
Katwyk tile
The S table I made for coverings out of foam.
It all started with the designers signature S on her card.
The I had the idea to create a table base out of that shape.
Unread 04-25-2015, 06:45 PM   #39
Katwyk tile
I cut some 3lb foam into the S shape
Unread 04-25-2015, 06:48 PM   #40
Katwyk tile
Then I waterjet two pieces of aluminum for the top and bottom.
Unread 04-25-2015, 06:51 PM   #41
Katwyk tile
Next I welded some aluminum sheet onto the thin edges.
And put a coat of Styrospray 1000 where the foam was thin.
Unread 04-25-2015, 06:54 PM   #42
Katwyk tile
Tile time
Unread 04-25-2015, 07:05 PM   #43
Jc0379
Josh B & S Home Improvement/ Owner
Rod the finished pictures of that were amazing! Your creativity with foam has got me using more of it lately. Always coated with Hydroban of course.
Josh
Jc0379 is offline   Reply With Quote
Unread 04-25-2015, 07:08 PM   #44
Katwyk tile
Forgot to mention I covered the aluminum sheet with GreenSkin.
Unread 04-25-2015, 07:11 PM   #45
Katwyk tile
Grouted with Latictete Plasma grout.
Why does sealer Foam chefwong Cleaning, Restoration and Sealing 2 08-09-2012 05:40 PM
foam board bentoveragain Professionals' Hangout 7 10-06-2009 07:38 AM
Tile Repair Job -- Foam Backerboard Turned Odd Brown Color NoviceDYI Tile Forum/Advice Board 10 01-24-2008 06:29 PM
Replacing 1" Blue Foam Shower tile backing with durock cungar Tile Forum/Advice Board 1 05-18-2004 04:10 PM
foam backerboards dale Professionals' Hangout 11 09-11-2001 06:16 PM
