Unread 02-16-2013, 10:55 AM   #16
Katwyk tile
I'm proud of this one because my 22 year old son set all the tile. We started out with a big pit and it took 70 cinder blocks to build this. The French Vanilla stone I got on close out for 49 cents per foot.
Katwyk tile is offline   Reply With Quote
Unread 02-25-2013, 11:08 AM   #17
dgunnels
Neesie
dgunnels's Avatar
The washer should not have to bend over (bad on the back) and should not have to pick up the washee, so raise it up, put in steps or a ramp. Flexible hose with adjustable nozzle is a great idea too. Towel rack and/or hooks nearby is a good idea too.
Neesie
Denise Gunnels, Realtor
http://www.harrynorman.com/agents/17291-Denise-Gunnels
dgunnels is offline   Reply With Quote
Unread 02-26-2013, 06:21 PM   #18
JTG
JTG's Avatar
Built a seat that is much more comfortable than the edge of the tub. I use a detatchable hose with a sprayer that I can control the on/off. The quick connect is in line. Scooter likes the shower floor vs the tube a lot.
Jerry
Santa Seattle
Ballard
http://www.facebook.com/home.php#!/SantaJerryinBallard
JTG is offline   Reply With Quote
Unread 02-26-2013, 08:36 PM   #19
Topspin
SchluterUgrad
Topspin's Avatar
Hey Rod, your dog washes look fantastic. What do you do underneath the pan of your dog washes? That's a lot of space to fill probably 25 cu ft feet or more. Is it a big foam block these days? A wood framed deck Or just totally solid cement blocks?
And on your trough drains what do you do again for your tapered sides on the inside trough section? Just cut slivers like a half inch at drain tapering to nothing at the ends? Or just leave it unfinished?
Unread 04-22-2015, 10:40 PM   #20
Katwyk tile
I have been doing dogwash/utility sinks almost in every home I do lately.
Unread 04-22-2015, 10:42 PM   #21
Katwyk tile
Trench drain.
Unread 04-22-2015, 10:45 PM   #22
Katwyk tile
Ready for tile.
Unread 04-25-2015, 10:06 AM   #23
eurob
Not...Sure
Rod,
Looks like you are using more and more foam in different applications . What are the setting materials used for tilling them ?
Roberto
Unread 04-25-2015, 11:43 AM   #24
Steve in Denver
Steve in Denver's Avatar
Steve
Steve in Denver is offline   Reply With Quote
Unread 04-25-2015, 11:50 AM   #25
Well thought out and nicely executed, Steve.
Unread 04-25-2015, 12:05 PM   #26
davem
davem's Avatar
Rod that pic almost looks like a computer generated image.
Unread 04-25-2015, 06:27 PM   #27
Katwyk tile
I've been coating the EPS with Hydroban and setting the tile over that with Laticrete 253
Unread 04-25-2015, 06:31 PM   #28
Katwyk tile
Unread 04-26-2015, 08:12 AM   #29
eurob
Not...Sure
Thanks , Rod.
It looks like a concept that is ready to sale on a larger scale ....... how much do one unit would cost ?
I may have another question , if I may , what are the other steps necessary to complete the tiled unit ...... meaning ready to be used ?
Roberto
Unread 04-26-2015, 04:04 PM   #30
Katwyk tile
Roberto,
They are $421 plus shipping and handling .
The unit is assambled, waterproofed and has the drain already installed.
It has a 2" abs pipe coming out on the bottom.
My contractors run a hot and cold hose bib out the wall into the garage and after a mop sink valve gets installed into the back of the unit , hoses get hooked up like a washing machine.
Should I try acid wash? tbrim Tile Forum/Advice Board 9 03-02-2007 11:50 AM
Vinegar wash??? When?? Aces High Tile Forum/Advice Board 3 01-10-2005 08:43 PM
do i need to wash Unregistered Tile Forum/Advice Board 2 09-11-2004 12:52 PM
Vinegar wash Unregistered Tile Forum/Advice Board 3 09-11-2004 11:46 AM
acid wash feded Cleaning, Restoration and Sealing 2 03-11-2004 09:04 AM
