Unread 01-11-2021, 10:17 PM   #1
Harblock24
What tool to chip out mortar for air register?
I realize this is very basic, but the air register no longer fits after the floor tile install. The hardened mortar is peaking out too far, and I want to be sure not to compromise the integrity of the tile job. What’s the safe way to do it? Thanks!
John
Harblock24 is offline   Reply With Quote
Unread 01-11-2021, 10:38 PM   #2
BIGPHIL
Chisel and hammer, rub brick, sub compact saw with diamond blade, angle grinder with diamond blade. Any of those or a combination of them would do the trick. Just take your time and go slow so you don't make more of a problem for yourself ;-)
Phil
BIGPHIL is offline   Reply With Quote
Unread 01-11-2021, 11:37 PM   #3
I'd put a towel or some such object down the vent to catch all the trash. Be careful removing it, so nothing falls down the vent. I lost a good tape measure that way once.
I'd use a hammer and chisel. The power tools will generate a lot of dust, something that isn't necessary for such a small task. Use an old chisel, cause it'll be in bad shape when you're finished. Or just get a cheap one from Harbor Freight.
Unread 01-12-2021, 07:49 AM   #4
Harblock24
Okay. Thanks to both of you!
John
Unread 01-12-2021, 08:21 AM   #5
You might think about cutting a piece of cardboard that's just big enough to wedge in that space. Keep it within an inch or two of where you need to chisel. Then, once you're done chiseling, vacuum the chips off the cardboard.
Unread 01-12-2021, 03:12 PM   #6
Harblock24
I went slowly with a hammer and chisel and cardboard below which went well. Thanks again!
John
Unread 01-13-2021, 11:11 AM   #7
speed51133
I vote for a multi tool with a carbide bit. This one is my go-to.
https://www.amazon.com/DEWALT-Dwa421...80027324&psc=1
Just incase you want to go back in time and do it again.
Unread 01-13-2021, 11:25 AM   #8
Harblock24
Haha. I do love my multi tool. I forgot about it. When I got it I was looking for anything I could use it on. Kinda like I look for any new food I can put butter on.
John
Poster can't register Lazarus Professionals' Hangout 6 04-25-2016 07:11 PM
Vent Register Dam for SLC Pour TeeRiddle Tile Forum/Advice Board 4 09-01-2015 08:13 PM
remote mortar application tool? unclejemima Professionals' Hangout 5 05-27-2015 06:11 PM
Tile over heat register? Dog paws Professionals' Hangout 10 05-25-2007 10:30 PM
Pressure to register Unregistered The Mud Box 10 05-11-2004 09:16 AM
