Unread 01-08-2021, 03:55 PM   #16
Elkski
Elkski's Avatar
So there is a slope on the joists? That would help by 1". I didn't show anything about the door. My drawing is sideways but it is how flashing needs to look to protect that red corner. I was trying to show how hard it is to flash areas like that where 3 planes meet.
I made sketches and had a sheet metal shop fabricare pans for my two pella sliding doors. One pan 60" and one 80". I also have used the plastic door pans in my garage and they are no good. The plastic cracks.
https://www.thermatru.com/explore-pr...ct-information
Teddy
Unread 01-08-2021, 04:42 PM   #17
Tile & Stone Guild
King Of Tile
Any exterior deck we do has a roofer involved, Troba mat, mudbed,ditra, and kerdi,You dont have room for that Personally I would not do this job based on your height issues and recommend getting a roofer and put Trex or similar and skipping the tile.
Jeff
Tile & Stone Guild is online now   Reply With Quote
Unread 01-08-2021, 11:28 PM   #18
Undr_prsr
On the joists, there is not a slope. Any slope there is is actually going in the wrong direction (towards the house just slightly. Overall it is null, but between a couple members that is a little variation. but I would call it no slope.
Thanks for those links. The sill pan link is great. I was looking for something like that.
The TREX is beautiful. I am seriously considering this. I also never thought a roofer for the job. I did seek a second opinion from a tiling company and maybe having a "specialist" do the balcony work, and let the stucco company do the stucco work. I really like this TREX stuff.
Regarding the flashing, that is very helpful on so many levels. It gives insight into what to keep an eye out for.
I already had observed a small detail that caught my eye, they did not use any hangers for the ledger and joist connection to frame the balcony and wanted to rest only the ledger on the beam column and let the joist essentially be supporter only by the generic nails they used.
For stucco I think they got it covered, for some of these other details, they cannot be an expert in everything and I am considering pulling a permit to ensure it passes inspections.
Also the outside roofer is a great idea!
Jay
Undr_prsr is offline   Reply With Quote
Unread 01-09-2021, 10:32 AM   #19
Jay, pulling a building permit on this project is a very good idea, but keep in mind that the building code is the absolute minimum requirement for any portion of the construction and many code compliance inspectors are not even aware of all those minimums. You can't depend upon code compliance to save you from less than competent contractors.
Once you have satisfied the structural requirements of your local code, I'd strongly recommend you find one of the ceramic tile industry accepted preparation methods that fits your application and do whatever it takes in your particular situation to prepare your structure to use that method.
Not really reasonable to depend upon outsiders such as you'll find on the Internet to see and correct all deficiencies you might have. Best we can do is tell you in general what you need to accomplish your goal. You need to determine what it will take in your specific situation to make each of those things happen.
We can tell you the deck must be properly sloped; we can tell you what you need to do to slope it. We can tell you that it needs to be made properly watertight and flashed to adjoining structure; we can't tell you exactly how that must be done without being on site. We can tell you what types of materials you must use or not use to prepare for the ceramic tile installation; you'll need to make the selections to suit your application. Etc.
Katwyk Tile Exterior Balcony Install Concept Katwyk tile Professionals' Hangout 40 12-13-2012 05:40 PM
Exterior Balcony in PA Hafer Tile Forum/Advice Board 13 10-12-2009 05:18 PM
Exterior balcony advice Joe L. Tile Forum/Advice Board 4 08-06-2008 08:05 AM
Exterior Balcony Job Floorit Professionals' Hangout 28 01-15-2006 05:27 PM
tile over exterior wood framed balcony wazoo Professionals' Hangout 5 10-20-2005 07:41 PM
