Unread 01-02-2021, 08:22 AM   #1
Don Monfils
Pro Carpet
Don Monfils's Avatar
Flat pebble tile
I have a job where the customer wants this pebble/ stone installed in a 3’ x 5’ entry way. I’ve never done anything like this. I was thinking of using a 1/4” x 1/4” square notch trowel. Another installer mentioned removing the tile from the mesh and install them one by one , to avoid seeing lines between the sheets.
My question is how do I keep the thin set from being as thick as the stones ( where the grout goes) ( with the big voids between stones) ? Would I knock the trowel ridges down with the flat side of the trowel?
Don
Don Monfils is offline   Reply With Quote
Unread 01-02-2021, 08:54 AM   #2
Tile & Stone Guild
King Of Tile
Some we pull from sheets and some we don't, depends how they key together. If you can see the sheets when you lay them out than peel. Just from the pic they probably need to be peeled. I use a worn down 1/4 and keep it turned down. Never really had a issue with bleed through.
Jeff
Unread 01-02-2021, 09:00 AM   #3
CaliGrown
CaliGrown's Avatar
1/4” trowel is good to go, I’d pull them off & set them one by one. Let’s you sort out the uglies and you can get away without any cuts. I’d put the baseboard up first so you don’t have to scribe to the tile after.
Christopher Machado
1 (916) 990-1751
CaliGrown is online now   Reply With Quote
Unread 01-02-2021, 10:17 AM   #4
There's some really large gaps between those pieces. They didn't try very hard to get them close. Another vote for pulling them off the sheet. Just don't spread very much thinset at a time. I cut notches in the end of a margin trowel. It works real well, reaches into tight areas better than a trowel.
Unread 01-02-2021, 03:24 PM   #5
Don Monfils
Pro Carpet
Thanks guys !
Don
Unread 01-02-2021, 07:24 PM   #6
CaliGrown
CaliGrown's Avatar
Are those Hemisphere pebbles? Kona sands?
If so here’s two pans when set individually, did it after wall tile was set & grouted. Client had us take out all of the reds and other undesirable pieces, big pro when setting one by one.
Christopher Machado
1 (916) 990-1751
Unread 01-02-2021, 08:43 PM   #7
Don Monfils
Pro Carpet
I have only seen a pic of the tile, don’t know the manufacturer.
That looks good.
Don
Unread 01-03-2021, 03:09 AM   #8
Those flat stones don’t change their appearance as much as rounded stones do when they’re grouted...but they do change. It’s probably a great idea to make a sample board and grout it for the client to approve before committing to setting the whole job.
Unread 01-10-2021, 07:25 PM   #9
Don Monfils
Pro Carpet
I wanted to thank you guys for your help.
I finished the job today. I dry laid some sheets, and
It didn’t seem to show the edge of the sheets to bad and the
customer liked it) without peeling off the stones.
I can’t believe the amount of grout I went through.
I thought is looked pretty decent for my first rodeo.
Don
Unread 01-10-2021, 07:44 PM   #10
Yo, Don!!
Looks very nice.
(Did I mention that I taught Don everything he knows about setting tile? )
Unread 01-10-2021, 07:51 PM   #11
Yeah, that does look really good. Really good.
And did I mention that I taught Kevin everything he knows about setting tile?
Small Floor -> Large Tile and How Flat is Flat? Eldudarino Tile Forum/Advice Board 9 09-23-2016 12:53 PM
Grout for flat pebble's up to 3/4" joints coz Tile Forum/Advice Board 2 05-12-2015 01:12 PM
Wrong grout for flat pebble shower floor? brgirl Tile Forum/Advice Board 17 06-06-2014 10:31 PM
How flat is flat for SLC- leave good enough alone? 1/4 in 4 feet? luciphil Tile Forum/Advice Board 11 05-07-2009 09:52 PM
best way to tell if floor is level/flat-and other flat surface issues!? acid Tile Forum/Advice Board 9 05-12-2005 10:32 PM
