Unread 01-06-2021, 10:50 AM   #16
Schluter will provide a warranty even if you only OHM the cable before, during, and after installation. But they will extend the warranty if you meg it also.
As far as the rug goes, best to avoid altogether, but the ones with a non-slip rubber type backing are the worst. They say not to place a rug anywhere on the heated floor, I don't recall them singling out the location of the heat sensor, Technically, I don't believe the sensor to be a thermocouple, though I concede the thermostat probably won't operate without the sensor.
Unread 01-06-2021, 12:27 PM   #17
Elkski
Elkski's Avatar
yes just like you need the cable 4" away from cabinets a rug will allow that area to get to hot. It has to be a thermocouple . It would not be that hard to cut the cable because you get to cleaning out excess thinset and its easy to grab something sharp.
Teddy
Unread 01-08-2021, 07:33 PM   #18
ejc_1
Thanks guys, sorry I just checked in.
Ed
ejc_1 is offline   Reply With Quote
Using Modified Thin Set for Marble Tile Over Schluter Ditra Heat sfklaas Tile Forum/Advice Board 14 02-20-2019 11:38 PM
Ditra heat question chapinpark Tile Forum/Advice Board 45 01-27-2016 09:19 PM
Ditra Heat Question. My Dream Tile Forum/Advice Board 10 11-29-2015 05:47 PM
What temp do you set your electric radiant heat at? yds Tile Forum/Advice Board 8 09-17-2010 06:47 PM
Question for heat mats + Ditra kamik19 Tile Forum/Advice Board 1 11-21-2005 04:27 PM
