Thanks cx!
Okay, now to post all my photos up to this point. There's 60 of 'em. I've already resized them.
I know, I know, y'all would rather have me host 'em here, but I'm not gonna do that. Imgur is a solid host, and I've used it fer years with no problems. If it
were to go down, well... Then I'd reupload 'em here.
Anywhoo, here we go. From the beginning, up to today:
Here's the beginning, with the old tile still in the bathroom. Had to replace 60 year old pipes, so the plumbers jackhammered through this bathroom, thru to the bathroom behind that back wall, all the way to the front yard. This is what they left me with.
Was gonna go with one of these here fiberglass shower pans, before I decided I'd rather dive right in to doin' one myself.
Demoed the walls, so much thinset behind the old CBU's!
Removed old ceramic floor tile, and applied the first coat of SLU Primer.
Second coat of primer is dry, ready to spread the SLU! Put up a perimeter dam of automotive weatherstripping, also 'round the floor plumbing fixtures. I went with a cheapo option fer the SLU: Sika Self Leveling Underlayment. Hindsight is 20/20, I woulda not only gone with a better product, but I'd have mixed it a bit thinner than I did. At least I learn real good.
Had my brother mix the second bucket of SLU, and
TRIED ter maintain a wet-edge. I didn't have a spiked roller,
or spiked shoes; only a squeegee. You can see where the first pour on the right meets the second, left pour.
SLU dried, purty flat, but it wasn't perfect!
Finished removing drywall, sistering studs, and most of the prep on the walls for the
shower area. Them red bricks were bricks I applied some RedGard to. I decided to ditch them bricks, and go with just regular pavers, so don't pay 'em any mind.
Here's all o' mine sistered studs, as well as blocking.
Right corner shot of sisters and blocking.
Again, pay them red bricks no mind...
Here's the other part of the bathroom entrance wall. My house is rather ****ed, as can be seen. Anyways, the studs on that wall were only outta plumb to the left side of the doorway, reducing down to zero by the right corner.
Had an old floor HVAC register hole which needed fillin'. Covered the old duct opening with duct tape, then applied expanding foam as a "casing" 'round the perimeter of the hole. After that cured, I poured-in some regular old concrete.
Used some floor patch compound to cover the mess underneath.
Tiles chosen! 12"x24" rectified porcelain, with bullnose.
Matching hexagonal tile for the shower floor.
Cutting and dry-fitting the stock pavers for the curb.
Layin' out my pavers.
Set the first course of bricks with modified thinset. (Note: I have no idea what I'm doin' with any of this project, literally flyin' by the seat of my pants. I feel lucky I didn't soil 'em thus far.)
Level first course.
Another shot of the first course.
Second course of curb bricks laid. Still level.
Preparing to lay the pre-slope with deck mud.
Sandy, cementitious snowball, easily crumbled, quite dry.
Using FlexBond modified thinset to bond the deck mud to my slab.
Perimeter (level!) and of an appropriate height/slope from the drain: 1/4" per foot.
More Preslope.
Filling-in the preslope.
Finished preslope! God, was I proud of this!
Checking slope.
Detail shot of slope.
Trying the liner with duct tape.
Screwed-in my first liner.
Marked my sistered studs with masking tape for later reference while I could.
Flood testing the first liner. I say
first liner 'cuz the first liner failed the flood test! The culprit: I used WAYYYY too much adhesive on one of the corner dams, which squeezed out, puddled, and ate a hole right in the corner.
NEW LINER, passed the flood test, this
was the failing corner from above. All is well with this one!
Lath in place. NO PUNCTURES ON MY LINER FER THE CURB WHATSOEVER!
Top mud bed poured, lookin' good, feelin' good. The tile comes up over the top of the drain by a hair.
Dry fitting shower floor tile.
Purty dry top bed. Formed the curb with fat mud/stucco base coat. Real interesting stuff.
Put some cardboard shims up to account fer me not notchin' my studs all proper-like.
Startin' ter put up the CBU panels.
More CBU.
Even more CBU.
Finished puttin' up CBU!
Final shot of fresh CBU.
Taped.
Second shot of tape.
Final shot of tape.
Began mudding with modified thinset.
Mudding seams.
Final mudding of seams shot.
Touched up curb with some modified thinset.
Began patching the floor with Henry Feather Finish. The lil sharpie lines you see are perimeters of low spots. Afterwards, I went in with a diamond-cup grinder wheel and plenty o' PPE, and fixed this right up. You can see some RedGard 'round the filled floor register, 'cuz the second coat of patch (didn't use the feather finish here, I used some other not-so-good, premixed product) I added was a lil too thick. It developed shrinkage cracks. So, I troweled some redgard on.
Me, after usin' the diamond-cup grinder wheel. Dust city.
Floor is flat as a carpenter's dreamgirl, only not as easy to nail.
Flat floor topside.
Layout 1 (All darker colored tiles are stock/uncut. The greenish area is where I'll put a niche.)
Layout 2
Layout 3
Question: Fer my layout, do y'all suppose I should balance the bullnose trim as is shown in the above last three photos, or should I run 'em full from the top down, having a single cut at the floor?
