Originally Posted by Elkski
What is the exterior made of?
painted stucco and nothing else. Houses in FL are made to breath. No moisture barriers on the inside as well (unless its a shower of course).
That window has got to go.
Agreed. I just wanted to check with you all in case there are requirements I should pass to the window company.
I hate replacement windows without new construction flanges that are properly flashed in before the siding material is out on. Non flanged windows rely on a caulking bead to seal. To seal to what is the question.
Yeah, another window in the house leaked from an aging caulking bead to the stucco.
I fixed it with
OSI's Quad max i picked up in HD and it has been holding up well.
An outside picture of that window would help.
Attached. That circle I believe is just architectural foam.
You would be surprised how high some of these guys will climb to a ladder. That's a baby window. I say go square window.
Yes, that's the plan. Just a bit of a pain since I have to go through HOA approval for an architectural change.
Did you get that platform out? It does look like someone tried to make some design statement. Unless it was for the drain line.
I have given up on taking the platform out. After I started this thread I realized why it is there. There is no crawl space underneath. The entire platform is a roof over a balcony. So yes, the plumbing runs through it and it is raised so that the p-traps don't protrude to the balcony below...
See pic.
It was originally very unsafe. You had to go down the height of the shower curb + height of the platform. I am hoping to mitigate it by having the shower door open to the platform first, so that you can then separately just step down from the platform (i.e. two separate steps instead of one big leap).
So does a furring strip + cbu goes inside the window opening, butted against the window?
The window opening is much deeper than the depth of a window jamb.
