Old 03-11-2019, 06:35 PM   #1
Pentheon
Bryan
Sealing travertine
Few questions. I should seal the travertine main bathroom floor (12×24), shower floor (2×2 squares), and 8x20 shower walls before I grout right? Then I can grout and seal the grout after?
Any suggestions on a great sealer for the travertine and grout? Also what kind of grout do you recommend?
Bryan
Pentheon is offline   Reply With Quote
Old 03-12-2019, 07:10 AM   #2
I've grouted a lot of travertine with no sealer on it. If you are going to seal, I would wait until after grouting and seal everything at once.
Old 03-12-2019, 09:27 AM   #3
Pentheon
Bryan
Oh ok I've just heard that sometimes it can stain.
I noticed on the tile I cut in the doorway that the film seems to be staying. Think its stained or buff it out?
What brand do you recommend for grout and sealer?
Bryan
Old 03-13-2019, 06:54 PM   #4
Pentheon
Bryan
Stonetech bulletproof work good on travertine?
Should I seal the shower floor also?
Bryan
Old 03-13-2019, 07:18 PM   #5
Yes, and certainly yes
Old 03-13-2019, 09:33 PM   #6
Da Home Builder
StoneTech Professional indicates the use of Bulletproof for porous surfaces. Your Travertine porous?
Difference of opinion, but I would recommend not sealing the shower floor.
Old 03-13-2019, 10:32 PM   #7
Pentheon
Bryan
Honestly I'm not sure if it is, how can I tell?
What's the reason you wouldnt seal the shower floor cx?
Bryan
Old 03-14-2019, 07:03 AM   #8
Pentheon
Bryan
Or what about Miracle Sealants 511 Impregnator*from the blue store. I see its half the price and wouldnt have to get it shipped. Is it not as good of a sealer since its cheap?
Bryan
Old 03-14-2019, 08:22 AM   #9
Da Home Builder
I've never used the 511 sealer, Bryan, but it gets good reviews here.
I wouldn't seal the shower floor because it slows the passage of water vapor and the drying of the floor. And the only purpose of the sealer is to help prevent staining and allow for easier cleanup of spills and such. I've found that the red wine spills in that area tend to wash away down the drain almost as soon as they happen. Your mileage may vary.
Old 03-14-2019, 08:30 AM   #10
Pentheon
Bryan
Appreciate the feedback. Is there an ongoing discussion about this? Curious to hear pros and cons of each.
I would assume still at the very least seal the shower walls and the main bathroom floor correct?
Bryan
Old 03-14-2019, 10:51 PM   #11
With areas that are not subjected to potentially staining liquids, there’s no reason to seal. And in a shower where you want moisture to escape freely from within a tile assembly, sealing works against the “moisture management system” that’s called a shower.
I won’t generally seal anything in a shower. No floors. No walls.
Old 03-15-2019, 10:14 AM   #12
Pentheon
Bryan
Makes sense. So it sounds like I shouldn't even bother sealing the main bathroom floor either right? Then again what about foot traffic with shoes possible dirt etc?
Now what about grout? Same thing?
Bryan
Old 03-15-2019, 07:14 PM   #13
Depends on what grout you decide to use.
Old 03-15-2019, 07:44 PM   #14
Pentheon
Bryan
I was thinking about trying out mapei flexcolor cq
Bryan
Sealing Travertine rtede Tile Forum/Advice Board 8 12-16-2011 10:44 PM
sealing travertine brusu Cleaning, Restoration and Sealing 1 09-20-2010 11:56 AM
sealing travertine wallygater Cleaning, Restoration and Sealing 14 10-18-2008 06:09 AM
Sealing Travertine travman10000 Cleaning, Restoration and Sealing 11 09-12-2007 08:59 AM
sealing travertine churchcamp Cleaning, Restoration and Sealing 2 11-18-2004 10:40 AM
