Unread 06-23-2016, 12:23 PM   #16
CaliGrown
CaliGrown's Avatar
Thanks Jim and Steve,
In regards to the KerdiFix or Silicone, would I still cut out a noche in the tile for the shelf or would it adequate enough of a bond to apply the shelf with Kerdi fix directly along the mosaic and along the sides of bullnose pieces?
Thanks Steve, the mosaic runs vertically along the wall and through the niche.
Christopher Machado
1 (916) 990-1751
Unread 06-25-2016, 02:15 AM   #17
CaliGrown
CaliGrown's Avatar
Shelf added
Added the shelf today, cut out a noche through the mosaic in the niche and used Kerdi fix to attach the shelf then caulked around each edge. Seems to be holding up fine, if I need to support it better In the future, I would add some pencil strip underneath both ends on the inside corners of the niche to support the underside of the shelf.
Christopher Machado
1 (916) 990-1751
Slope Subflooring for linear drain kvn27 Tile Forum/Advice Board 2 10-30-2014 05:09 PM
Deck Mud Calculator with offset drain Matt Lengeling Tile Forum/Advice Board 6 08-20-2013 08:58 AM
Can I use the offset drain fladug Tile Forum/Advice Board 12 11-19-2011 09:49 AM
Drain offset between pan and floor EJ Downey Tile Forum/Advice Board 9 06-29-2008 05:23 PM
Shower Pan buildup - offset drain Hokie01 Tile Forum/Advice Board 3 11-15-2007 06:29 PM
