Unread 04-20-2016, 06:01 AM   #1
rugman8
Homeowner left grout on WAY too long - what to do?
Got a call on this (see pics) - slate from HD. It is not acid sensitive. About 132 inch long backsplash. I haven't seen it yet - just the pics as it is a little far away. Whats the best way to tackle this? Grout is unsanded.
Bob - grout911.com
rugman8 is offline   Reply With Quote
Unread 04-20-2016, 04:02 PM   #2
Peerless Tile
Tile Contractor
By starting over....Not acid sensitive....who cares, the rest of the stuff around probably wouldn't appreciate the amount or duration it was around.
SC Greg
Peerless Tile is offline   Reply With Quote
Unread 04-20-2016, 04:37 PM   #3
Eschbach
Tile Contractor-Virginia
easier to start over
www.eschbachrenovations.com
Virginia Installer of Schluter Kerdi and Kerdi Board Waterproof Showers
Excellence is no accident
Eschbach is offline   Reply With Quote
Unread 04-20-2016, 06:31 PM   #4
The others are probably right about starting over. If that's out of the question, maybe a scrub pad on a grinder. Be ready for the dust.
Unread 04-21-2016, 03:58 AM   #5
Mr.Miyagi
Re-Remodeler & Re-Tiler
Mr.Miyagi's Avatar
Apply more grout
Cary
Mr.Miyagi is offline   Reply With Quote
Unread 04-21-2016, 01:16 PM   #6
dhagin
So, if you intend to spend time & money trying to clean that up, and actually succeed, how well do you think that unsanded grout will hold up?
Rip out and redo is the only good thing to do here.
dana
Unread 04-21-2016, 06:19 PM   #7
Just In Tile LLC
Just In Tile LLC's Avatar
Wow! I'm trying to think of other options besides tear out, all of them just aren't worth it. It's one of those accidents you put your head down, grit your teeth, and slowly start pulling the tile off the wall. If tear out is not in the cards I'd go with Davy's suggestion, but it's one of those more work then redoing in my mind. Sure like to hear back how this ended up.
Justin
Unread 04-22-2016, 08:20 AM   #8
Pfeffer
this should go in the 'pics of the WORST tile' thread.
good grief. burn it down. burn it all down.
Pfeff
Pfeffer is offline   Reply With Quote
homeowner wants to clean her unsealed grout...and GO with your products! rctools Cleaning, Restoration and Sealing 5 02-19-2015 07:36 AM
New Homeowner - Advice for Cracking/Wet Grout at Corners in Shower Cyclonite Tile Forum/Advice Board 5 07-27-2011 08:03 AM
hardened grout left on tiles too long!!! Help? laddertruck Tile Forum/Advice Board 9 11-23-2007 05:50 PM
He left grout on too long... EmileeAW Tile Forum/Advice Board 8 11-19-2007 05:23 PM
HELP ! Grout left on unglazed porcelain tiles too long ! Christopher1963 Tile Forum/Advice Board 9 06-11-2004 08:55 PM
