Unread 01-03-2012, 09:55 AM   #1
jason78
Modifying Silestone cutout
DIY here and looking for some advice.
My kitchen countertop is 2cm thick Silestone. It is cut for a slide-in range with a cutout of 29.75" wide by 23" deep. The cupboards underneath are set 30" apart.
I need to replace the range (broken) and it seems most slide-in ranges now require a full 30" cutout.
Does anyone think it's possible for me to sand off 1/8" from each edge?
I figure this is safer than trying to cut it off (worried about chipping)..even if it takes me hours to do.
Thanks in advance
Jason
jason78 is offline   Reply With Quote
Unread 01-03-2012, 10:13 AM   #2
Sanding would be better than cutting. Dusty as heck, but better.
Unread 01-03-2012, 10:52 AM   #3
Pirate
If it is a slide-in range, isn't there a flange on top of the range that fits on top of the stone? That's the way mine is anyway, so a little chipping isn't an issue, since it can't be seen.
Randy
Pirate is offline   Reply With Quote
Unread 01-03-2012, 11:54 AM   #4
koihito
A person, like you.
koihito's Avatar
Whether you sand or cut it will make a big mess, but yes, you should have no problem doing either.
I assume by sanding is "better" Bob means "safer", as in less likely to screw up, and if you are unsure of your skills than I would agree. If you are confident in the use of a grinder save yourself a bunch of time and cut it
Nate
www.mikoskiconstruction.com
Unread 01-03-2012, 01:00 PM   #5
jason78
Great, thank you for the advice. Any ideas on what grit sandpaper I should start with? 80?
Jason
Unread 01-03-2012, 04:15 PM   #6
Jason,
I'd start by dryfitting the actual stove before sanding anything. Maybe measure a few dozen times first. IF needed, then proceed to sand 1/16" off each side and dry fit again. Its easier to sand more off than it is to glue some back on.
Unread 01-03-2012, 05:16 PM   #7
koihito
A person, like you.
koihito's Avatar
Been there, done that Words of wisdom, Paul.
Nate
Unread 01-03-2012, 08:27 PM   #8
60 or 80 grit would be a good start.
modifying the modified bullbarrel Tile Forum/Advice Board 8 07-30-2010 08:42 PM
Help Modifying an Existing Shower Surround Blumba Tile Forum/Advice Board 8 11-04-2009 12:24 PM
Modifying Kitchen Backsplash JoeT Tile Forum/Advice Board 6 04-03-2009 10:51 AM
Modifying Your Thinset??? David Dodson Professionals' Hangout 6 04-27-2005 05:12 PM
Replacing/modifying subfloor for ceramic tile dlg Tile Forum/Advice Board 3 05-26-2004 04:13 PM
