Unread 06-01-2010, 06:35 AM   #1
NeedHelp
Grout joints aligned with hardibacker joints
Have hardibacker down in kitchen, and our preferred tile layout has the grout joints lining up over the hardibacker joints. Is this a problem? Should we adjust our tile layout to avoid this?
NeedHelp is offline   Reply With Quote
Unread 06-01-2010, 06:53 AM   #2
It's not a problem provided you installed the Hardibacker in accordance with the manufacturer's instructions, and your subfloor and joists are up to specs.
Remember to tape and mud the backerboard joints as you tile, if you haven't already done so.
Unread 06-01-2010, 08:44 AM   #3
Brian in San Diego
Brian in San Diego's Avatar
Hey NeedHelp!
I just want to say "Welcome Back!" After an eight year absence you return. That has to be some sort of record. We would appreciate you adding your first name to your signature line...you may be close to being a charter member!
Question about taping Hardibacker board joints Armand Tile Forum/Advice Board 3 06-07-2007 10:33 AM
Is silicone ok at hardibacker joints. Krempley00 Tile Forum/Advice Board 9 03-11-2007 03:33 PM
taping Hardibacker joints dougrus Tile Forum/Advice Board 1 07-25-2006 09:06 AM
Hardibacker butt joints joea Tile Forum/Advice Board 7 09-13-2005 06:28 AM
Hardibacker and expansion joints chrishallowell Tile Forum/Advice Board 2 04-15-2002 04:45 PM
