Unread 05-11-2009, 02:41 PM   #1
Page
"Tile Dog"
Page's Avatar
Schluter Kerdi As Crack Isolation membrane
Has anyone used Schluter Kerdi as a crack isolation membrane on concrete slab control joints? Does it meet specs? If so, how is it applied? If not, what do you recommend? Thanks.
Page
Remember, Just because you're paranoid doesn't mean they're still not out to get you!
Page is offline   Reply With Quote
Unread 05-11-2009, 03:01 PM   #2
ddmoit
ddmoit's Avatar
I'd suggest Noble's membrane. Kerdi does not claim to have crack isolation properties.
Dan - a DIYer in SE Tennessee
Unread 05-11-2009, 04:12 PM   #3
It's in the financial interest of the manufacturer of any tile installation products to claim any and all potential applications for their products, Page. Check the advertisements and specifications for Kerdi and see if you find reference to A118.12 in there.
Unread 05-11-2009, 04:27 PM   #4
Page
"Tile Dog"
Page's Avatar
So.....the answers no, right?
Page
Unread 05-11-2009, 04:51 PM   #5
jgleason
jgleason's Avatar
Correct. Schluter doesn't make that claim for their Kerdi product. I'll second Dan's recommendation for the Noble product.
Unread 05-11-2009, 05:34 PM   #6
Schluter®-KERDI
Schluter-KERDI is a bonded waterproof membrane with limited crack-bridging capabilities. It is made of soft polyethylene, which is covered on both sides with a special fleece webbing to anchor the membrane in the thin-set mortar.
Unread 05-11-2009, 05:51 PM   #7
jgleason
jgleason's Avatar
If you need crack isolation then you would want something that meets ANSI 118.12. Kerdi does not.
If all you're after is a little extra insurance, it might be better than nothing. I wouldn't use it as a crack isolation material when there are other, better alternatives.
Originally Posted by from the Schluter Kerdi specs
Schluter ®-KERDI is suitable for wall and floor surfaces where protection against the penetration of moisture or other harmful substances is necessary. Applications include showers, steam showers, tub surrounds, and areas surrounding swimming pools.
Schluter ®-KERDI meets the American National Standard for Load Bearing, Bonded, Waterproof Membranes for Thin-Set Ceramic Tile and Dimension Stone Installations (ANSI A118.10) and is listed by cUPC®.
Found this thread too, interesting reading. Check out Brian's last post where he relays back what his Schluter rep said... http://www.johnbridge.com/vbulletin/...ad.php?t=59793
Unread 05-11-2009, 07:48 PM   #8
blah!
http://www.johnbridge.com/vbulletin/...5&postcount=20
Do I need membrane crack isolation? smarsh Tile Forum/Advice Board 7 11-28-2006 12:03 PM
Sheet Membrane Crack Isolation Tumbled Tile Forum/Advice Board 3 03-13-2005 07:55 PM
Help!! crack isolation membrane Chris McNeal Professionals' Hangout 16 09-19-2004 06:47 PM
crack isolation membrane? zelenak Tile Forum/Advice Board 5 01-17-2004 08:11 AM
New Crack Isolation Membrane kurtafs Professionals' Hangout 26 01-11-2004 09:30 PM
