Unread 10-11-2019, 04:24 PM   #1
ChiknNutz
Leaking shower, partial tear out?
I have a leak in an upstairs shower that appears to be a leaking pan. It is for sure not the drain and does not appear to be from the supply lines, so has to be a leak in the pan somewhere (have opened up drywall for inspection). This is an older home, built in 1988. We are recent owners so don't know the whole history of this house. We have a home warranty but they don't replace tile, so stuck doing it myself. Although I know the tile is not supposed to be the water barrier, but I first thought it was the grout around the perimeter, so removed that and caulked it. It did improve it, but it is leaking again after a few weeks. I cannot see a clear place it is leaking but it must be the pan somehow.
I took some pix so you can see the tile layout and seeing if I can get away with just pulling the pan and a few courses of tile, or if that is just asking for trouble and should just pull it all and start over. I really don't want to pull it all, am not fast at this, and it will literally take me weeks to do it if I pull it all. I do realize that matching it is not possible, nor do I wish to try, but is replacing some going to look like crap or is there a way to make it look decent? Thanks for any advice offered.
Chris
ChiknNutz is offline   Reply With Quote
Unread 10-11-2019, 04:33 PM   #2
Welcome back, Chris.
I personally consider any shower receptor replacement without replacing the entire shower to be a temporary measure to buy some time 'till it's more convenient to do the full shower re-build. Even if you manage to do a good job of the pan and lower wall replacement, you rarely have any method of tying the new waterproofing into the existing wall waterproofing, if any.
The aesthetics of the pan replacement can be acceptable with a complementary or contrasting tile and calling it a feature, but the reality is that you're gonna get to do the full replacement sooner or later anyway.
Unread 10-13-2019, 07:43 AM   #3
ChiknNutz
Ugh, as I suspected but had to ask. Okay onto the next step. The one and only shower R&R I've done in our previous home, I used the Schluter system. It seems like one of the best out there, but to me, was considerable work. I used the thinset applied membrane, not Kerdi-board. Since this will be done on a strictly part time basis, I know this will take me weeks to finish if I go this route again. Is there another system that is still a quality item that takes less time to do? Maybe the Kerdi-board is faster, but probably more $$$, haven't checked yet. Aside from a typical membrane-and-tile solution, are there other shower installs that could be done faster? I have not looked into a molded panel system, but would consider it if they actually last. I don't care if it looks as nice as tile, just want a quality system that I don't have to worry about later. A long lasting product matters to me more than it looking super cool.
Chris
Unread 10-13-2019, 09:39 AM   #4
I'd say to stick with the Kerdi system. It's going to be about the fastest way for you to do it especially since you have experience with it.
We use to do quite a lot of shower pan change outs. Remove the floor and walls up about 12 inches along with the curb. Then install a new pan and tile it back. Like Cx said, it's a Band-Aid but it can last if the pan is what's leaking.
I would still plug the drain and fill the shower from another source other than the shower head just to make sure the leak is coming from the pan.
Unread 10-13-2019, 10:20 AM   #5
ChiknNutz
Agreed. It is a pretty slow leak, takes a couple showers for it to actually leak. I really thought it was a pinhole leak in the plumbing but it really doesn't seem to be. I do need to be sure it's the pan and not go thru all the trouble of a R&R only to find out it still leaks.
Chris
Unread 10-13-2019, 03:44 PM   #6
TGF
We had a leak that sounded a bit like this. It wasn't in the base where we thought, it was around the shower control handle. Water percolated down and it looked like it was coming from the base. Is the control handle trim well-caulked to the wall? Try covering with a huge amount of saran wrap and masking tape for a few days.
Just call me T.
TGF is offline   Reply With Quote
Unread 02-15-2020, 10:00 AM   #7
ChiknNutz
So I haven't yet tore into this as it has not leaked since and have no idea why. I am convinced it is not the plumbing, but must be somewhere in the tile. It leaked 3 or 4 times and then hasn't since. I don't want to close up the drywall only to have it leak again, cuz I know it will as soon as I do. I really don't want to tear this whole thing out for no reason, but clearly there was a problem. But, how could it just quit?!
Chris
Unread 02-15-2020, 10:07 AM   #8
Welcome back, Chris,
Not much you can do, will just have to wait it out. As you've likely guessed there's a good possibility that it's going to leak again. Just deal with it when it does, maybe start putting resources aside and a plan in place for when it does.
Unread 02-15-2020, 04:20 PM   #9
rmckee84
rmckee84's Avatar
A flood test would probably help you eliminate plumbing issues for sure and possibly find the point of origin.
Ryan McKee
Unread 02-15-2020, 08:59 PM   #10
To do what Ryan recommends, Chris, you must get the water to fill the shower receptor from a different source than the shower itself.
Unread 02-16-2020, 11:34 AM   #11
ChiknNutz
Understood. I tried this a few months back, filling it from the nearby tub spigot. I did not experience a leak at that time, though I admit I did not plug the drain sufficiently for it to sit full for several hours...only several minutes. I presume I need to fully plug the drain and fill the pan just short of where it would leak over the curb and let it sit until it leaks again.
Chris
Unread 02-16-2020, 11:41 AM   #12
That's right, Chris. To test the pan and drain assembly correctly you need an inflatable plug for the side of your drain riser. Big box stores will have them, about 20 bucks. You insert it down far enough so that it is completely and only in the riser.. Inflate to something like 14 PSI (the instructions specify), then fill the pan. Place a stack of coins, or otherwise make a mark at the water level so you can gauge if it drops. Then wait for as long as you can stand waiting, 24 hours should do, unless the water level is obviously dropping.
Unread 02-16-2020, 11:49 AM   #13
Chris, you may need to get a test ball and extension hose from a plumbing shop. That way you can plug it down in the riser pipe below the drain. I'd hold the water down about 3/4 inch below the top of the tile curb. Like Cx said, get the water from a different source, water hose thru a window, something like that.
Edit; what speedy fingers Dan said.
Partial retiling of shower for cosmetic purposes asmad Tile Forum/Advice Board 3 09-27-2013 01:01 PM
Partial tear out and redo shower Nornee Tile Forum/Advice Board 8 11-11-2012 11:21 PM
Partial removal of tiles in shower? drewgold Tile Forum/Advice Board 4 05-26-2012 08:41 PM
Leaking pan / partial Kerdi on wall? Paul-MI Tile Forum/Advice Board 7 05-22-2010 01:00 PM
20 yr old shower partial rebuild KarenAmm Tile Forum/Advice Board 6 01-18-2006 06:37 PM
