Unread 09-09-2019, 04:33 PM   #16
rudyrock
Modifying Kerdi niche
Hi All
After deciding to build my own niche, i have come across a challenge or maybe i'm the challenged one ;-) I have searched the site and didn't find a good description of my issue. Maybe its common sense... but that is very uncommon according to Mark Twain.
I am ready to build the niche to fit the stud bay/plumbing constraints but before i mess up I need to ask a few questions.
My tile is Anatolia 3/8", 11 3/4 x 23 3/4 Will be Installed vertically with 1/8 grout joints. I want the grout joints to line up vertically; not possible to fit to horizontal joints due to stud bay & plumbing restraints I'll be using Jolly trim around the niche. Ill use the 3/8" tile for the niche sides and for top of niche and marble for middle and bottom shelf.
I need to figger out the dimensions of the niche box to fit the short side of the tile and then the best way to come up with an accurate way to measure to line up the verticals.
Help appreciated thx
Rudy
rudyrock is offline   Reply With Quote
Unread 09-09-2019, 10:30 PM   #17
I'm not sure I understand everything about your last question, but hopefully this tells you what you need to know.
I always do a dry layout on the floor for something like that. If you try to go by measuring individual tiles and add 1/8" for grout joints, you'll be off a little.
Measure, then check, re-check, and re-re-check your measurements. Make sure you use the actual spacers you plan to use during the installation to get everything as accurate as possible.
Niches are a tough thing to get exactly right. Some installers chose not to install them until they have the tile installed on the wall up to that point, so they can get the spacing just right. That's another option.
Unread 09-10-2019, 08:27 AM   #18
rudyrock
Thanx for the suggestion.
Ill clear an area on the floor and dry fit w spacers, Jolly trim and all. Hadn't thought of that one. It s just that 1/8 joint doesn't give much wiggle room for error. Dont want to start tiling first, just think that might get me in trouble, but i see the advantage to that as well. Nothing but respect for you pros... who do this everyday.
Rudy
Unread 09-22-2019, 11:45 AM   #19
rudyrock
Modifying Kerdi niche +
Same project as Niche
Find my Kerdi shower pan was cut 1/2 short on the curb side. Now how did that happen: :scratch
Anyway I am thinking that I will fill that 36" x 1/2" space with deck mud. Hope I can find Mapei mud tomorrow. Hate to buy 94 lbs of cement for this little oops. Thought I would use the curb as a batter board against which I would stuff in the mud. Or maybe there is another alternative.... putting the cutoff piece of pan back and kerdi fixing it Or?
Thx
Rudy
Unread 09-22-2019, 12:32 PM   #20
Lou_MA
Thinset the cutoff piece back in. Or if you’ve got extra 1/2” Kerdi board just cut a strip and thinset it in place.
Lou
Unread 09-29-2019, 11:54 AM   #21
Tiger Mountain Tile Inc
For the niche, I usually add 1/8 inch onto my measurements for a safety net. Then the tile will usually hang past just a small amount. Then any gap gets filled in flat with thinset once the tile dries.
Jim Upton
New DIYTileGuy blog post: Flood testing a shower pan: Why it's done and how to do it
Unread 10-02-2019, 06:41 AM   #22
rudyrock
Same project;: Reviewing Schluter install guide just before installing shower tray...and I see an asterisk...pg 14 says "when installing stainless steel drain the membrane is adhered to the bonding flange with Kerdi fix"
I have a stainless drain. Is this something you all have done ? Maybe some sort of chemical reaction concern?
At least I have not mixed thin set yet
Was gonna install today and then this.....
Rudy
Unread 10-02-2019, 06:50 AM   #23
rudyrock
OK so I called Schluter. They explained they make a stainless flange which i was not aware of. The asterisk on pg 14 of the install manual refers to the flange not the cover.... unclear what they referred to but im good to go now
Rudy
Unread 10-02-2019, 07:37 AM   #24
Just mix your mortar on the thin side to prevent build up, Rudy.
Unread 10-02-2019, 12:12 PM   #25
rudyrock
Smile
thanx Dan pan is in and drying. Seems I always mix the mortar thin anyways
Rudy
Rudy
Modifying an MK880 saw FSmyles Professionals' Hangout 11 06-18-2013 08:57 AM
Modifying Silestone cutout jason78 Tile Forum/Advice Board 7 01-03-2012 08:27 PM
modifying the modified bullbarrel Tile Forum/Advice Board 8 07-30-2010 08:42 PM
Modifying Kitchen Backsplash JoeT Tile Forum/Advice Board 6 04-03-2009 10:51 AM
Modifying Your Thinset??? David Dodson Professionals' Hangout 6 04-27-2005 05:12 PM
