Unread 06-10-2019, 04:48 AM   #61
thedayrock
I was thinking about using using the kerdi Shower curb for concrete floor. The shower floor will be done with deck mud.
Any opinions on best method for shower curb on concrete floor? I am nervous that a styrofoam curb will not hold up to wear and tear or hold a very large shower door.
Derek
thedayrock is offline   Reply With Quote
Unread 06-10-2019, 05:31 AM   #62
For over 40 years I've used plain 2x4's without a known problem. I Tapcon the bottom 2x4 to the slab and nail the next two to the bottom one. Sometimes I'll used a treated 2x4 for the bottom piece but never for all 3. Then I mud the curb like is shown in the shower construction thread you'll find in the Liberry.
Some installers like sticking bricks to the slab for the curb. That works too.
Unread 06-10-2019, 05:35 AM   #63
I've personally not used one, Derek, but have read many posts here from those who have. The foam curbs are a non issue; once you cover them with tile or a solid surface those coverings spread the load out over a large area so the whole assembly can easily carry the load of a door.
One thing I wouldn't want to do, however, is install a door with bottom mounted pivot. But that would be true of any curb
Unread 06-10-2019, 07:05 AM   #64
Elkski
Elkski's Avatar
I just read all of this thread this morning with my breakfast. Quite a concrete expedition demolition job. I'm glad you went with the linear drain I wished you had posted more pictures of how you fixed the plumbing . mess.
I'm not sure I would build out the wall. A 1.5" sliver tile wouldn't look bad if it's the same size all the way across.
Teddy
Jacuzzi to Shower Retro boulderz Tile Forum/Advice Board 6 01-09-2019 11:04 AM
Turning a jacuzzi tub into a tub/shower bzarna Tile Forum/Advice Board 3 07-23-2008 08:18 PM
Using Jacuzzi platform as part of shower seat, waterproofing personalt Tile Forum/Advice Board 5 09-28-2005 04:57 PM
KERDI shower system vs. Jacuzzi preformed shower pan saydee19 Tile Forum/Advice Board 9 05-05-2004 07:29 PM
basement jacuzzi tub/shower Boe Tile Forum/Advice Board 3 06-10-2003 08:58 PM
