Unread 09-29-2019, 08:31 PM   #31
Think I'd not try the teflon tape there, Jim, just a little pipe dope to lubricate a bit and maybe help it seal. But neither is recommended by the manufacturer.
I prefer the threaded connection in that application.
I've no experience yet with the Shark Bite fittings and I'm still a bit leery of them.
Unread 09-30-2019, 06:11 AM   #32
I'd also be leery of reusing the compression fittings, but a tiny bit less so if I reused the valves currently in place, keeping them on the same pipes you took them off from. However, since you mentioned that two of the pipes are too short to cut and install new fittings onto, keep in mind that if you do roll the dice you won't know if reuse will work until after you install your new drywall.
Since I see insulation, are some of those supply lines on an exterior wall? If so, and if your area experiences freezing temps, you'll want to be meticulous with your insulation.
Unread 09-30-2019, 05:22 PM   #33
jamesb2
CX: I agree that I'm leery of push-to-connect fittings except for temporary usage. However, I think folks are starting to use them where you can get at them (don't seal them in the wall). It looks like all the manufacturers make them now.
Dan: Yep. I'm leaning to putting the same valves back on and crossing my fingers. Get to it early in the morning to give me plenty of time for multiple trips to the hardware store. And yes, one exterior wall, but not the one you would think. The pictured insulated wall (sink) is interior...not sure why they insulated? The toilet is the true exterior wall and I will be making sure to re-insulate.
Jim
jamesb2 is offline   Reply With Quote
Unread 09-30-2019, 06:07 PM   #34
PC7060
PC7060's Avatar
I will quite often (dare I say routinely? ) reuse the nut and the compression ring when installing new valves. And be sure to replace with 1/4 ball seal type.
You may be able to work off the old ring so you can replace both. Give it a try and let use know how it comes out.
Insulation may be for sound dampening. I insulated my bathroom interior wall to rescue the sound of my kids late night showers.
Unread 09-30-2019, 06:29 PM   #35
jamesb2
PC: Thanks for the input. I'll report back once I decide and execute.
Now, I need my electrician friend to get some time for me. I decided to leave the shocky/burn down the house stuff to a professional. I think I can do it, but I thought it better to leave it to someone that knows they can do it.
Jim
Unread 10-01-2019, 06:17 AM   #36
PC is braver than I, as I wouldn't install new valves onto already crushed/deformed compression sleeves. Though the seat surface and angle of the new valve should be the same as the old, if it isn't because of manufacturing tolerances it may not seal. If the old valves are the cheepo builder grade, multi turn with plastic stems, absolutely bin those and install the 1/4 turn ball valves PC mentioned.
I do the same whenever I have an interior wall open; insulate it for sound reduction.
For that toilet line in the exterior wall, you might consider sealing the exterior sheathing to the studs first, which will help reduce any exterior air from entering the wall cavity. Also try to keep the copper supply line as physically close to the back of the drywall as possible, which will allow it to absorb some heat from the drywall.
Need advice...installing shower drain in basement brian8377 Tile Forum/Advice Board 107 05-21-2014 10:38 PM
basement shower w/cast iron drain Mr. Fran Tile Forum/Advice Board 6 04-03-2012 06:16 PM
Basement Shower with Floor Drain birger31 Tile Forum/Advice Board 5 10-05-2010 02:54 PM
installing shower over basement floor drain jeffrey Tile Forum/Advice Board 3 11-27-2006 06:19 AM
Basement shower drain mikeyboy Tile Forum/Advice Board 4 05-08-2003 03:28 PM
