Tuscan LS--Strap Storage
Hello All:
I've gotten a lot of good advice trolling this forum over the years--thought it was time to contribute.
I am going to be laying 18x18 rectified porcelain and decided to use the TLS. I used the Tornado LS a year ago for 12 inch marble and it worked great. But you need two hands (at least I did): one to hold the strap and one to tighten the nut, and I thought this would be difficult with 18 inch tile.
Anyway, I could not find any information on how to store the TSL straps after soaking if they were not going to be used right away. I emailed the company, and their response is below.
How this helps.
Richard
Hi Richard,
We have found (through trial and error) that ideally 2% moister in the nylon straps is the best.
• Straps only need one soaking.
• Best to soak the straps for 20 minutes in hot water the day before using or at least the night before use. Drain the excess water off after the 20 minute soak and let the air dry the straps overnight (or ideally, let them dry out 24 hours before using).
• Do not leave the straps soaking in water while you are using them. If the straps have too much moister, it weakens them.
• The straps can be stored in an open or closed container, either way.
Thank you,
Christopher Kufner
christopherkufner...at...tuscanleveling.com
Richard
