Unread 06-21-2019, 11:20 AM   #16
Catmandu
Yes, it was brand new, bought the same day. I installed it and it was very rigid.
Cate
Catmandu is offline   Reply With Quote
Unread 06-21-2019, 12:23 PM   #17
Elkski
Elkski's Avatar
Maybe just build a custom niche with kerdie board.
https://floorelf.com/building-a-niche-with-kerdi-board
Chamfer the edges for your bull nose. Wrap kerdie from wall inside. Cut and fold some corners with kerdie fix
Teddy
Unread 10-10-2019, 07:49 PM   #18
Catmandu
flood test
I started the flood test of the pan last night. 24 hours later, the water level hasn't dropped at all and I can't see any signs of water below, although I only have easy access to the area near the drain. What concerns me is that the top of the curb is wet in spots. I spilled a small amount of water while filling the pan, but only from the first gallon as I was careful not to splash after that. The wet area has now spread. When I touch the darkened wet areas, it's not just damp--there is actual water present on my finger. I thought what spilled on top would not soak in and spread, but rather should evaporate. Is this normal, or something to be concerned about? The 1st photo is at the start of the test, and the 2nd photo is 24 hours later.
The heat's not on so there's no air blowing, but it probably hasn't gotten below 66° inside so it's not cold.
Cate
Unread 04-27-2020, 08:40 AM   #19
katayers
Cutting quarter round for niche edges
Hi Cate -
How did you cut the quarter round to get the corners to match up for the edges of niche?
Kate
katayers is offline   Reply With Quote
Unread 04-27-2020, 10:36 AM   #20
Catmandu
On a wet saw. Stand the piece up on one of the flat edges and run it through the blade at a 45° angle. You have to hold it firmly so it doesn't fall over.
Cate
Quarter-Round on Shower Base mortier Tile Forum/Advice Board 16 08-25-2018 09:21 PM
Corner prep for quarter round trim? slb Tile Forum/Advice Board 9 05-04-2017 08:35 AM
Kerdi shower with quarter round Emer Construction Tile Forum/Advice Board 2 01-09-2008 11:59 AM
Quarter round/trim install rdwitch Tile Forum/Advice Board 11 03-18-2005 12:53 PM
Quarter Round DR Tile Forum/Advice Board 4 01-27-2005 11:28 PM
