Unread 06-08-2021, 09:16 PM   #1
allday2232
Order of Events for Leveling Floor
Hi Guys,
I'm working on remodeling my laundry room which previously had carpeting in there. The subfloor is plywood over joists over a crawlspace. Room is approximately 5' wide and 15' long.
Width-wise towards the back of the room, it looks like the concrete stem walls below settled quite a bit. So over the 5', there is about a 3/4" difference. That difference starts to level out as you come to the front of the room to where its pretty much level.
Since I'm putting a washer/dryer back there, I want to try to get it a bit more level before I put tile down. I want to make sure I got my order what I do proper.
I was planning on putting down 1/4" Durock with thinset underneath and screwing down per standard recommendations. Once that was down, I was going to work on leveling the back by putting down a self-leveling underlaying. I called Mapei and they recommended their Ultraplan Easy product since it can go from a feather edge (on the level side) to up to 2" on the bad side.
Once the floor was level and proper, I would do a standard thinset and tile.
Does this sound like the right order? I dont think I want to level the floor first as then the cement board screws would crack the self-leveling.
Thanks.
allday2232 is offline   Reply With Quote
Unread 06-08-2021, 09:49 PM   #2
Welcome to the forum, allday!
Yep, you got it in the right order.
Unread 06-09-2021, 11:24 AM   #3
allday2232
Awesome. Thanks!
Now I need to just not screw it up....
AP
Unread 06-09-2021, 11:33 AM   #4
Welcome, AP.
First thing I would recommend is that you evaluate your joist structure and your subflooring to determine if you qualify for a ceramic tile installation without some improvement. I'd also want to determine the reason for such a dramatic out-of-level condition.
You can start on the joist structure using our Deflectometer (above in dark blue bar) for an initial go/no-go reading. Then you'll want to know the type and thickness of your subflooring and relate that to your joist spacing.
Unread 06-18-2021, 08:55 PM   #5
allday2232
Thanks guys. I think I'm ready to move forward.
Now, the next debate...I'm trying to decide between Hardi and Durock. Does their seem to be any consensus on which is better or is it still down to preference for a floor tile installation?
AP
Unread 06-18-2021, 09:48 PM   #6
Ford, Chevy, Dodge. Personal preference, AP. You'll get strong arguments for and against on both products.
Have you evaluated the joist structure?
Unread 06-19-2021, 08:46 PM   #7
allday2232
I did. Ran the numbers on the Deflecto and came up with a deflection of L / 2410 (2X10 with 6' width and 16" OC).
Back third of the room (15' long total) has a good slope width-wise almost 3/4" and as you get closer to the middle of the room its almost level (about 1/8" off).
Took a look under the crawlspace and don't see anything significant. Everything looks good so I can only assume there was some good settling in the foundation at that back part. It appears to be old settling as I took a window out on that back wall that was put in the early 90's and I see the contractor made a "wedge" shim on top of the window to account for the slope. Hasn't look like it has moved since.
I ran my 4' level across the room today in all different directions and its actually flatter than I thought. Didn't have any high ridges or rocking on the level. Knocked back down a few nails.
AP
Unread 06-19-2021, 10:37 PM   #8
Originally Posted by AP
...(2X10 with 6' width and 16" OC).
You understand that it's the unsupported span of the joists you're looking for here, not the span of the tiled area, yes?
Unread 06-20-2021, 06:51 PM   #9
allday2232
Correct. The room is like a galley. Its only about 6' wide. Load bearing walls on each side that the joists are sitting on.
Tile is going wall to wall.
AP
shower tiling/grouting order of events? MiltonMike Tile Forum/Advice Board 5 09-27-2007 04:11 PM
order of floor rgwelli Tile Forum/Advice Board 5 11-01-2006 07:52 PM
To be certain I have the order of events Snapper1 Tile Forum/Advice Board 5 05-27-2006 06:55 AM
