Unread 06-03-2021, 08:42 PM   #1
-djd-
Mind the Gap
Hi folks, long time listener, first time caller.
First DIY tile project here converting old tub enclosure to shower. Did a lot of homework including referring to these forums on more than one occasion. Despite all that, somehow I’ve miscalculated my total height and have ended up with a 3/4” gap between top tile course and finished ceiling.
Options I can see at this point:
  1. Caulk it white, blend with ceiling
  2. Add another grout line (3/16”) and tile sliver course. Then white caulk to ceiling.
  3. Possibly same as #2 but with little to no vertical grout lines.
Maybe I’m over thinking it or missing another obvious simple solution so appreciate your bright ideas and shared experience here.
TIA
David
-djd- is offline   Reply With Quote
Unread 06-03-2021, 10:19 PM   #2
Welcome, David.
What is the composition of the ceiling?
Unread 06-03-2021, 10:21 PM   #3
-djd-
Thanks CX.
It’s plain ole greenboard, painted white.
David
Unread 06-03-2021, 10:23 PM   #4
How 'bout a second layer of drywall (not MR Board) to lower the ceiling to match your tile installation?
Unread 06-03-2021, 10:33 PM   #5
-djd-
Hmmm… I like the out of box thinking but think this would cause even more aggravation. Ceilings are already quite low at 7’ and the shower ceiling is continuous to rest of room (which is finished) so would mess with lighting, duct work, fan, etc.
David
Unread 06-03-2021, 11:31 PM   #6
PhilWA
you could put some kind 1/2" or 5/8" trim in there to fill the gap, and grout in between. -I did that with my shower at the top because of a similar situation as you. Since I already had schulter metal trim in my shower I just used teh same color/material.
Phil
PhilWA is offline   Reply With Quote
Unread 06-03-2021, 11:49 PM   #7
CaliGrown
CaliGrown's Avatar
Either a sliver of tile, or trim. Pencil trim, ogee trim or chair rails. Or you can rip down some quartz or granite to match your benchtop and have an accent/feature in place of the slivers.
Christopher Machado
1 (916) 990-1751
Unread 06-04-2021, 04:45 AM   #8
-djd-
Thumbs up
Thanks folks. I like the trim idea. Will look more “intentional”.
One more trip to the tile shop!
David
Unread 06-04-2021, 06:32 AM   #9
smifwal
I think a couple of good old coats of drywall mud would do the trick. You can leave space for a grout line or not, dealer's choice. I would float it out about a foot or soto a nice feathed edge like you would with any mud work. 3/4 might be to much to in the small space of your shower to float oit far enough but I think it is worth trying
Unread 06-04-2021, 10:34 AM   #10
Lou_MA
Some type of pvc crown moulding
Lou
Lou_MA is online now   Reply With Quote
Mind if I join in? My Dream Tile Forum/Advice Board 15 01-17-2011 01:00 PM
Inquiring Mind dcj79 Professionals' Hangout 5 10-14-2007 07:12 PM
Never mind Sparta and the 300. Shooter The Mud Box 6 09-14-2007 01:05 PM
Never mind who won... DonB The Mud Box 9 01-07-2006 12:53 AM
Mind Wrap Hobbit The Mud Box 7 02-05-2003 09:03 PM
