Unread 06-03-2021, 01:50 PM   #1
krc
Karl
Ok - dumb tile saw question here....
I have an old MK tile saw but thinking of upgrading for larger tile formats.
In looking around, though, I don't understand why the wet tile saws I see all have an "arm" to hold the motor and saw assembly. This limits really the size to the left of the blade you can cut - correct? So if you have a 24x24 tile and you want to cut in half with a wet tile saw, what do you do? (I know you can get a slide cutter or whatever those are called that score the tile and break...)
Why are these wet tile saws not more like a standard wood table saw where there is no limit on the left/right side? Or am I misunderstanding something?
Seems like it would be easy to adopt a standard table saw mount and have it still be cooled with water.
What am I missing here? Angle of cut? What?
Just curious...
Karl
krc is offline   Reply With Quote
Unread 06-03-2021, 01:51 PM   #2
krc
Karl
and...
And, yeah, I suppose that is why you have a bridge saw? Still seems more complicated though...
Karl
Unread 06-03-2021, 02:21 PM   #3
Karl, I think the DeWalt 24000 will cut your 24" tiles in half. Others probably will also.
There are many table-saw-type wet saws on the market. Most of them use only 7" blades and none that I've encountered have the power of the overhead motor types. There are also hand-held wet saws that will do some tricky cuts if you're not in a hurry.
Snap cutters are available that will cut ten-foot tiles.
And, of course, there are the "bridge saws" that will cut some larger tiles.
They all have a place, I suppose, and you just need to decide what fits your needs and budget.
Unread 06-03-2021, 08:18 PM   #4
For me, even if a table saw-style of wetsaw had a smooth sliding tray and a powerful motor, I’d still object to my vision being obscured by either the clear plastic splash guard getting clouded or the water spray flinging at me and my eyes.
Tile layout dumb question.... OttawaP Tile Forum/Advice Board 5 03-22-2012 06:29 PM
Dumb Tub Saw Question MNTileGuy Professionals' Hangout 14 09-16-2009 06:25 PM
Dumb question... Closer_2001 Tile Forum/Advice Board 7 03-17-2007 05:42 PM
Dumb, dumb, Can I remove installed tile? cybercard Tile Forum/Advice Board 24 03-10-2007 03:26 PM
Risking a dumb question - Why not use caulk in tile joints? TJ Tile Forum/Advice Board 8 04-17-2005 09:32 PM
