Unread 05-26-2021, 10:46 AM   #1
Cam83
Will silicone caulk adhere to a resin patch?
I apologize, this question isn't directly about tiling and grout but i'm hoping someone may know the answer or be able to point me in the right direction.
I recently had to patch a corner of my bath tub with a fiberglass mesh and two part resin patch kit. Unfortunately the patch happens to coincide with where my tub meets the shower surround. will this be a problem when I go to seal the joint with caulk?
Any info/advice is greatly appreciated and thanks for your time!
Cam
Cam83 is offline   Reply With Quote
Unread 05-27-2021, 08:00 AM   #2
Hi Cam,
I'm pretty sure the silicone will work. Give it a try.
Pool Tile Repair: Leave old thinset? Use Bonding Adhesive? E-Z Patch Silicone? ChuckDavis Tile Forum/Advice Board 2 05-15-2018 01:17 PM
will thinset mortar adhere dry silicone lindam Tile Forum/Advice Board 3 05-24-2017 06:31 PM
Tec Skillset Silicone Caulk vs Tec Accucolor Silicone Sealant adellecave Tile Forum/Advice Board 3 12-24-2016 06:38 AM
How to remove silicone based sealer so i can use silicone caulk in shower lccavender Tile Forum/Advice Board 7 10-29-2015 05:19 PM
Caulk/grout repair - patch job or the whole thing? sugarsugar Tile Forum/Advice Board 16 03-02-2013 06:06 PM
