Unread 05-25-2021, 10:54 AM   #1
PhilWA
Tan Tub to Blue Shower Remodel
Here's my photo journal of my DIY project:
Phil
PhilWA is offline   Reply With Quote
Unread 05-25-2021, 10:58 AM   #2
PhilWA
Work in progress...
I want to add mosaic tile to the right wall (behind toilet and to function as vanity backsplash), up to around 4ft height. Trying to figure out how to trim the top edge of the mosaics before setting them.. These mosaics are only about 1/8" thick.. Any ideas?
Meanwhile, I'm working on grout and finishing drywall.
Phil
Unread 05-25-2021, 11:37 AM   #3
Welcome, Phil, looks pretty nice from here. I like the shower wall tile.
For finishing the top of the mosaic, have you considered one of the tile trims? Schluter makes a bunch.
Unread 05-25-2021, 12:28 PM   #4
PhilWA
Hey Dan,
I had to lookup on schluter's website to check, but they do have 1/8" height schiene profiles (L-shaped) listed. At the local stores, I've only ever seen the 1/4" height trims at the smallest. I do cringe at the thought of UPS shipping a couple 8 ft lengths of flimsy trim; maybe ill see if the local stores will order it for me.
Phil
Unread 05-26-2021, 02:32 PM   #5
BIGPHIL
BIGPHIL's Avatar
Looking good, Phil! I too like those wall tiles
Phil
BIGPHIL is offline   Reply With Quote
Unread 06-15-2021, 10:16 AM   #6
PhilWA
So I used some Mapei Mapesil T Plus 100% silicone at the bottom corners of my shower and along my glass door, but after a couple days it doesn't seem to be hardening/solidifying? The material seems to have a 'silly putty' consistency? Is this normal? When I've used clear/white silicone they seem to harden almost completely within a day..
I called mapei and they said to squeeze some out on board for a few days. After 20 hours, I scraped up some of the squeeze out and balled it up and mashed it; here's a photo of what the material looks like at this point (in my 72F house). I'll test again tomorrow.
Should I scrape this stuff out and try to source some regular Mapesil T (no plus)? I've used the 'siliconized' acrylic from 'Custom' brand in my other shower remodel, but that stuff has degraded after 3 years and needs replacement. The silicone color match products seem hard to find in local stores.
Phil
Unread 06-15-2021, 03:50 PM   #7
Jason@mapei
Jason Cantin Mapei Technical rep
Jason@mapei's Avatar
Do you have a picture of the Tube?
Jason
Jason@mapei is offline   Reply With Quote
Unread 06-15-2021, 04:06 PM   #8
PhilWA
bought these from lowes
Phil
Unread 06-16-2021, 12:41 PM   #9
PhilWA
After installing a sliding shower door, my heated towel rack looked like it would be too close to the door, so I ended up cutting a hole in the drywall to relocate this box 3 inches (further) away from the shower door. Now there is just barely 22" clearance between the open sliding door and the towel rack, hopefully that's enough?
Phil
Unread 06-16-2021, 12:48 PM   #10
PhilWA
Here's the photo of the Mapesil T Plus after 2 days. It looks like the 'warm grey' color is curing faster than the 'pearl grey'. The pearl grey seems like its taking too long to cure? I don't want to tear it out if I don't have to, so I'll give it another week while I work on the vanity tile backsplash.
Phil
Blue (Foam?) Shower Pan/Got wet HomeDepotAssociate Tile Forum/Advice Board 4 09-18-2015 08:47 PM
contractor installed blue drywall in shower mark999 Tile Forum/Advice Board 2 07-31-2015 08:37 AM
Blue shower coating? Didz Tile Forum/Advice Board 5 02-23-2010 08:06 PM
Larry's Blue Bath Remodel Larryl9797 Tile Forum/Advice Board 57 04-06-2009 07:50 AM
Pennsylvania Blue Stone in the Shower..... ajdedo Cleaning, Restoration and Sealing 2 11-27-2007 02:58 PM
