Unread 05-08-2021, 07:39 PM   #16
wraiththe
wraiththe's Avatar
Liars liars liars
Because we have not had a stove since monday....
One thing...
Even Schluter tech support told me I could use a 3/16 x 5/32 x 3/16 V notch trowel to put enough thinset down to place Shluter Edging...
JOLLY-AC 2,5mm A80MGS and my backsplash tile.
BS! My gut was telling me no way. NO WAY!
The tiles were rocking and would not really seat well.
So I back buttered the edge about 2 1/2" in from the edge before placing the tile and that seemed to work well. Fun cleaning the grout lines tonight.
Hope this is acceptable. It seems to have worked.
(Also wondering why the tile gave 3 dimensions for V-notched trowels?)
wraiththe is offline   Reply With Quote
Unread 05-09-2021, 12:20 AM   #17
wraiththe
wraiththe's Avatar
Unread 05-09-2021, 09:25 AM   #18
wraiththe
wraiththe's Avatar
Help, thinset haze on stone and graphite
Hi,
Need advice and tips on a problem.
My tile is finally up, but I have a haze from the thin-set. Have been using a sponge with a scruby side, but the haze is visible when dry... It has been over 12 hours and will be over 24 when I get back home.
I have noticed that after I use the sponge, no matter how often I clean it, the haze is still there, however, I can drag my finger through it and the powder is on my finger.
Tried a dry cotton cloth. The tile is still wet, I have to leave and cannot get a picture of it.
There are some crevices that I may need to use a knife... to scratch out. Hoping a stiff brush will do the job.
I have only done ceramic... and am concerned because of the way stone takes on water.
Going to use enhanced sealer before grouting. Was not expecting this to be a problem with setting the tiles, but it is.
Is there any product I can use that will facilitate getting rid of the haze?
Yes, I will be googling it and reading too... tonight when I get home.
Not afraid to put some elbow grease into it... just hoping it will come clean!
Unread 05-09-2021, 10:56 PM   #19
I see the sponge in a previous picture with a white, scrubbie side. That white scrubbie side doesn’t work well for me. The yellow side of the grout sponge is infinitely more absorptive and will clean the tile much more than the white side. You could also use a damp microfiber towel to clean mortar from the tile before it hardens. And if you’ve got mortar in the crevices of some tiles, you need to clean it before it hardens or it’s going to become a far harder job the next day.
Unread 05-10-2021, 01:29 AM   #20
wraiththe
wraiththe's Avatar
Oh the thinset is hard and I have not been able to get all of it off the sides and face.. I may have to establish a grid and do it section by section. It is very tedious.
I have been using one of those cheap snap blade utility knives (smaller size) It is an agonizingly slow process and a bit of a strain in some areas.
Haze. I had started sponging off the tiles after they set a little bit in the edging areas. However the haze kept coming back. Invisible when wet, but then obvious when dry. After pulling my finger over the tile and seeing the grit come off, I grabbed a clean white soft cloth and that seems to have removed most of the haze. The majority of it may have been just from the sponge? I kept cleaning it, but that must only go so far.
Due to the difficulty and the amount of extra thin set in some areas, I had quite a bit of thinset on the face of the tiles. Now I really wished i had sealed them before tiling.
Perhaps the next time I may use the double sided wall tile adhesion tape... mats.... what ever, and no edging.
It is hard to believe they never fail and send tile to the countertop...
I am guessing the edging would be near impossible to use with this product.
Unread 05-10-2021, 11:28 AM   #21
wraiththe
wraiththe's Avatar
Uneven tile makes me nervous for grouting. Tips?
Here is an image of my tile before grouting. It still needs some cleaning.
My two biggest concerns....
1) Whether to use 511 impregnator sealer, or 511 seal and enhance.
I plan to seal before grouting so the grout releases easier. Hopefully I
can do this with out getting it on the edges... so the grout will stick
the way it is supposed to. Having second thoughts.
2) Grouting: The tiles are all of varied thickness... even some of the tiles
themselves. I am concerned the grout lines may look bad. Guessing
they should fall back to the level of the lowest tile? In other words... if
one tile sticks further out like a shelf, I should try to keep the grout like
to the same depth on both sides... so the outermost edge is clean stone
and not grout.
Maybe I am thrown spaghetti on the wall here. I am alone on this.
Thinking #2 is good to try to get the grout lines flat and parallel to the wall
and not angled. (What I said in #2.)
Unread 05-12-2021, 06:34 AM   #22
You might want to experiment with both sealers on some left over tile so you can get an idea how they will look. The regular 511 might still enhance the stone a bit. but yeah, use one of them before you grout.
Anytime you grout tiles that protrude farther from the wall than others you'll be challenged with the grout lines. Those small pieces makes grouting that much more difficult. I'd suggest mixing very small batches and working very small area, starting with an inconspicuous area. You might be able to use a large sponge for the initial clean up but I'm pretty sure you'll have to resort to a much smaller one so you can detail the grout lines.
It'll take a while.
Unread 05-16-2021, 10:06 PM   #23
wraiththe
wraiththe's Avatar
Hi,
For getting the right color grout, I was given
Mapei Ultracolor Plus FA
A rapid setting all in one grout replacement ....
I am slightly concerned about getting ALL the grout off the face of the tiles on time because the tiles are uneven and stone with crevices... and because this is quick set.
I have sealed the face twice with 511 enhance and seal.
If I stop grouting and wet the face, will that extend the time I have to get the face clean? or is it pretty much a given set time.
Unread 05-17-2021, 09:20 AM   #24
wraiththe
wraiththe's Avatar
Backing showing through glass tile
HI,
Finally grouted my project. I am pretty sure the backing Fishnet) is causing this white bubbly effect through the glass tiles. I have two more walls to go and the tile is up. The only remedy I think is to go in with a tool and scrape them all back!
Any ideas or comments?
Unread 05-17-2021, 12:28 PM   #25
Take a careful look at the ungrouted walls and check to see how much thinset is in the spaces between the tile.
Unread 05-19-2021, 01:58 PM   #26
wraiththe
wraiththe's Avatar
follow up
Yeah, part is my fault for pushing the tile in too much, but really I just did it with the float. Then a two by four with a rubber mallot... tapping on it.
No one will probably see this, but I could use some advice. There are a few hundred tiles to fix... not all of them... but it has taken me several years and a few thousand dollars to get here... why give in now. I plan on fixing the tiles I have not grouted yet.
I have only grouted one wall. the grout came out great... except for some
of the tile:
Name:  glue and thinset bubbles.jpg
Size:  72.5 KB Name:  good tile .jpg
Here is a close up of some unused tile to show the glue on the sides:
Tools, some I have modified to have a bur at the end to catch the back edge, but really the trick is pushing back the glue (It is sticky like thick snot
I am practicing on the tile behind the stove, but am not doing so great and it takes a long time. Indeed the grout saw is helping speed it up, but really it is the glue and cutting behind the tile does not help.
I have marked the saw so I do not go too far behind the tile.... Very tedious.
So far.... still not that great.
Name:  best fix so far.jpg
From a distance the tile looks good, except for the squiggles.
I am not as happy with it as I thought I would be, but some lighting and appliances.... it should be really nice.
The outlet covers and switches were very very cheap. I want satin black, but who knew it would be so much more expensive (Lutron) Perhaps a different type would be better??? Or print vinyl and skin my own covers.
Also tried a mini engraver on unused tile... very vary bad idea.
Just bought the grout saw, a hook like blad, and some picking tools.
It is important to be gentle esp around the stone.
There is NOTHING I can find on the net about this... I have been searching a lot. Any advice would be appreciated... well... good advice.
Unread 05-19-2021, 11:57 PM   #27
wraiththe
wraiththe's Avatar
Better picture of glue on sided of tile
The right edge of the tile looks rippled, that is glue from the mesh netting that was on the back of the tile. It does NOT want to come off.
Unread 05-23-2021, 02:07 PM   #28
wraiththe
wraiththe's Avatar
Here is a small section of the second wall...
Using a oscillating multitool, I tried to get rid of the glue on the installed tiles
... the results were less than optimal.
But I think maybe better than the other tile?
Furthermore: After sealing the stones twice, I expected more of the grout to release.
I hope that now the grout is hardened I can scrub the tiles a little harder to get some of the grout off the faces in the tricky spots.
I tried my best wiping and wiping and wiping and wiping during grouting... but nothing I did during grouting would remove the grout completely... not even a toothbrush or stiff brush with non acid cleaner.
One more wall to go, most used so I would like it to be better. I have used x-acto knives and x-acto push blades... snap blades, grout cutters and the oscillating multitool (very carefully)
Name:  oscillating multitool.jpg
I am my own worst enemy and biggest critic
I miss when we used to get much more responses and advice from this forum. Not much help at all. Am I that boring, clueless, what?
Is there a better place to go for help... or do I need to hope on a paid site or something?
Last edited by wraiththe; 05-23-2021 at 02:12 PM. Reason: Grammar and extra comment
Unread 05-24-2021, 10:21 AM   #29
Kevin,
Sorry your back splash job has been such a challenge. As you have found, while a lot of tile - mosaics included, look great in manufacturers promotional photos they are quite difficult to install. Yours, with its mix of smooth stone, rough stone, and glass, many of varying heights, all held together with mesh and glue appears to be especially difficult.
We do try to respond to everyone's posts as timely as possible. Remember, though, that no one here is an employee; we all freely volunteer our time, experience, and knowledge as often as we can but we do have other things tugging at us.
Unread 06-07-2021, 10:05 AM   #30
wraiththe
wraiththe's Avatar
Seal Grout or caulk first???
Would like to know if it is better to seal the grout first, then caulk the intersecting surfaces first?
Also wondering if it would be better to just use 511 impregnating sealer, Enhancer, or a specific grout sealer? It is stone and glass tile...
Damaged cabinet due to backsplash removal Deb Gray Tile Forum/Advice Board 6 03-28-2011 05:34 PM
backsplash against wood cabinet Valeri Tile Forum/Advice Board 2 05-25-2008 06:13 PM
Gap between wall and countertop and backsplash...advice please?!? thriftymama Tile Forum/Advice Board 4 09-05-2006 11:19 AM
How to tie-in backsplash under kitchen cabinet Stuart P. Tile Forum/Advice Board 10 04-22-2005 08:21 PM
cutting pressboard at cabinet's edge. nightscout Tile Forum/Advice Board 3 03-30-2005 09:41 PM
