Old 11-08-2018, 10:10 PM   #1
Wordbrew
Anyone interested in helping me with my bathroom reno adventure?
Hi! Long time lurker, first time poster. I thought I'd hung out here long enough to know what's what, but as life likes to teach you the hard way, I'm quickly learning I don't know squat.
I won't bore you with the background too much aside from the fact that what started as a simple "refresher" has become a whole renovation due to an unexpected mess for the old subfloor (rot in the old t&g, portion of sub missing entirely, another portion crudely cut up 3/4 plywood nailed down).
Upon removal of the subfloor, I found that my joists consist of 2x6 boards set 16 oc, ~10-12 feet long, doug fir, good condition. When I go on the trusty deflecto calculator, I'm getting a deflection of just L / 144. Thumbs down for all tile. WTF.
What I'm not getting is how the previous owners were able to maintain a ceramic tiled bathroom for nearly 15 years in good condition. No grout or tile cracks. Just was a bit outdated for my taste. At L/144, I'd assume that should not be possible.
I'm in a 1940s home, raised foundation. The bathroom is center of the house, just 8x5 in size. The joists run perpendicular on top of at least two beams with foundation footings. Could that be helping to stabilize and minimize the deflection?
Long story short, I'm trying to figure out what I can do to make my floor more hospitable to tile. I'm already planning to block the perimeter edges and add staggered blocking between the joists to help reinforce it some. Anything else I might be able to do to help get my rating better?
To make matters even worse, I've got a height issue, so 3/4 plywood puts me equal to the hardwood flooring in the hallway leading up to doorway. My original plan was to put 3/4 plywood sub with a 1/2 underlay. Now I'm not sure of that even. I was going to try to settle for 3/4 plywood with a decoupling membrane (like Schluter ditra), but with the mini-joists underneath, I'm not sure it would make any difference.
I have a photo of the joists, but can't upload yet. Four joists run through the room. One joist is actually cut short in the section where the tub used to be. There's literally nothing in it's place, but at least the prior owners sistered it with another cut off, shortened joist.
Thoughts? Am I doomed to have laminate or shag carpet in my bathroom for all of eternity?
Many thanks in advance to anyone who can help.
Chris
Wordbrew is offline   Reply With Quote
Old 11-08-2018, 11:11 PM   #2
Welcome to the forum, Chris.
I'd go with the avocado green shag. You'll need an oil painting of Elvis to go with that.
Starting at the beginning: joists are measured by the longest unsupported span. So if they're 12' feet long, but have a support halfway through, the length measurement is actually 6'.
The species and grade are also important, so get those three pieces of information together (you already have the spacing) and give the Deflecto another run at it.
Old 11-09-2018, 12:12 AM   #3
Wordbrew
Oh man, talk about being stupid. That put me from L/144 up to L829! Thank you for correcting me on that.
Considering my plans to still reinforce some of the area, I wonder if I might be able to get away with a single 3/4 plywood. Or am I tempting the tile gods too much with that?
Chris
Old 11-09-2018, 01:11 AM   #4
If your joists are 16" on center, you could certainly install over a single layer of 3/4" plywood. Just make sure it's tongue and groove, installed with the face grain perpendicular to the joists, and has a face grade of A, B, or C.
Old 11-09-2018, 01:15 PM   #5
Wordbrew
Perfect! Thanks so much for the help. I feel at least one aspect of the remodel is going to go smoothly now. Plumbing is another issue entirely.
I will be sure to update as I move along with the entire process.
Chris
Been a while - master bathroom remodel - helping a friend DoofusOfTheDay Tile Forum/Advice Board 28 04-25-2014 04:01 AM
Matt's Bathroom Adventure Chief Newbie Tile Forum/Advice Board 23 05-27-2013 03:03 PM
Boo's Bathroom Reno Boo Tile Forum/Advice Board 6 03-17-2013 03:29 PM
Bathroom reno jkrale Tile Forum/Advice Board 11 03-27-2005 08:41 AM
John's bathroom adventure JRM Tile Forum/Advice Board 18 03-09-2005 10:08 AM
