Unread 12-30-2021, 08:42 PM   #1
Skoorbmax
Which schluter transition for Ditra-XL to carpet?
I'm a DIYer.
24" joists, 7/8" OSB single layer. Presently there is linoleum over 1/4 (?) luan (?) or plywood. I intend on removing that layer, going down to OSB, using whatever Home Depot grade modified thin-set is in stock and adhering Ditra-XL (the only one they accept for OSB), then the unmodified for the 7" tiles.
When I did this at a previous house I used Reno-U transition. The problem is, since I was on Ditra then also, the Ditra was visible under the strip. I never bothered lifting the carpet up near it to transition properly, and finally made it look nice when we installed thicker flooring a few years later.
With Ditral XL being even thicker I need somethign to drop height to the level of the OSB--or close. Is Reno-V going to be the ticket?
Arandar
Skoorbmax is offline   Reply With Quote
Unread 12-30-2021, 09:00 PM   #2
Welcome back, Arandar.
You'll need to 'splain that. Far as I know, Schluter has indicated Ditra over OSB for years. And years before they even started making DitraXL.
Can't say I completely follow your description of your problem. If you're just looking for something to transition from a higher tile installation to a lower carpet installation, the Reno-V might work fine. But without knowing the difference in level from the top of your Ditra to the top of your carpet, it's a little difficult to say for sure.
And a good bit would depend upon whether you like the look of the Reno-V in your application.
Unread 12-30-2021, 09:21 PM   #3
Skoorbmax
Ditral XL is the only ditra applicable to single-layer OSB with 24" joists.
Honestly, I do not like the look of Reno V. It's quite wide!
Arandar
Unread 12-30-2021, 09:40 PM   #4
So, it's the joist spacing rather than the OSB that's of concern. The Schluter requirement there also assumes nominal 3/4" OSB. Pretty rare in my part of the planet to see 7/8ths" OSB and I don't know what Schluter's position on that might be.
I've always preferred to tuck my carpet directly against ceramic tile in that installation. Might require ramping the carpet up on some tapered shims. There are materials specifically made for that, but it's also not uncommon to use cedar shingles for the application. That an option?
Unread 12-31-2021, 01:49 AM   #5
A tack strip would raise the edge of the carpet and hold it in place, but some shingles and carpet tape MIGHT work. Depending on the carpet, the cut edge may start to unravel unless covered or capped, so that could be an issue.
Unread 12-31-2021, 06:34 AM   #6
Skoorbmax
Thanks for the ideas. I am going to try and ramp it I think. If I'm lucky the luan's extra layer of wood, when removed, will be enough to hide the thicker profile of the ditra XL against carpet
Arandar
Unread 01-01-2022, 12:06 AM   #7
smifwal
What kind of carpet do you have? Normally we stack strip two pieces right next to the tile one right behind it and the pad overlaps the piece behind it. Surely the ditra XL and tile will not be more than 3/4 of an inch or will it?.
Want carpet <-> tile transition under door, but carpet doesn't make it zeande Tile Forum/Advice Board 10 10-31-2015 02:01 AM
Schluter for tile-to-carpet transition? VegasJeff Tile Forum/Advice Board 3 08-30-2012 06:36 PM
Schluter transition granite to carpet LadyDaleDIYer Tile Forum/Advice Board 8 08-28-2012 06:58 AM
Tile/Carpet Transition Mckenzie Tile Forum/Advice Board 8 02-19-2008 07:58 PM
Carpet to tile - schluter transition? kopacm Tile Forum/Advice Board 3 11-01-2006 01:03 AM
