Unread 07-30-2018, 10:20 AM   #1
Sbauer90
DIY grout disaster with Mapei Ultracolor Plus FA
We are a novice tiling DIY couple trying to improve our own home. And loved the color match of Mapei Ultracolor Plus FA to our tile. But we were not skilled to move fast enough for the quick set of the Mapei Ultracolor Plus FA grout. So we've made a mess of our grout lines.
Is there any possibility of reducing these grout lines to the 1/8th we were targeting using a chemical wash or equivalent. Or should I be investing in an oscillating tool and dig it out (my current expectation)
Since it is newly installed grout, would new grout adhere to the original grout if I removed it with the oscillating tool, in order to make it consistent and level?
Thank you for your advice and help!
Sarah
Sbauer90 is offline   Reply With Quote
Unread 07-30-2018, 12:49 PM   #2
You can try an oscillating blade, it might work. A grout bit in a Dremmel will also work although care has to be taken not to let it jump out of the joint and scratch the tiles.
Once you cut out the old grout, you can add new grout. You do need 2/3's of the joint depth for the new grout to grab hold.
Unread 07-31-2018, 03:59 PM   #3
Sbauer90
Thanks Davy. I think we'll try the manual grout saw to start. I appreciate your help!
Sarah
Unread 07-31-2018, 06:47 PM   #4
Mathman
No advice on how to fix the problem but we were going to use the same product on our backsplash and decided to use keracolor U with their additive and it worked well and was easy to work with. We split the mix of grout and additive so as not to mix as much and it seemed much easier to work with.
Kirk
Mathman is offline   Reply With Quote
Unread 07-31-2018, 07:10 PM   #5
Karls tile Inc
Tile and stone contractor Tile setter
What Davy said. Its not going to be easy and scratching or chipping the tile is going to be a issue.
Karl
Karlstile.com
Karls tile Inc is offline   Reply With Quote
Unread 07-31-2018, 07:12 PM   #6
Welcome, Sarah.
I hate to be the one to suggest it, but I think you might be better off just removing the tile and starting over. I think you might find it easier and more effective.
Unread 08-01-2018, 04:16 PM   #7
Sbauer90
Thank you all for your recommendations. We are going to try to be careful and save as many tile as possible.
Mathman - I'm glad your change in grout selection was successful!
Sarah
Unread 08-01-2018, 06:01 PM   #8
mark999
The longer you wait the worse it will be.
Mark
Unread 08-06-2018, 12:30 PM   #9
Joe-Tile
That grout is one of the best on the market, however small sections and small batches is how it is utilized best. Good luck on scraping out the old, it's a tedious process.
Joe
3rd generation Owner of Joe Tile
Quality tile installation since 1948.
Joe-Tile is offline   Reply With Quote
Unread 01-02-2019, 05:47 AM   #10
Davestone
Florida Tile & Stone Man
I know this thred is older but i was looking for help with this grout.The owner bought i never would have to use on this job...i am changing the grout to something i can work with.this was 3 hours work..i will never use it again.on something like this, flash time is too quick,it is too pasty and hard to work with.luckily i used a grout release or i would have really been sorry..
http://Davestonestile.com
Unread 01-02-2019, 05:50 PM   #11
BelkTile
BelkTile's Avatar
Wow, 3 hours, definitely look for an alternative!
https://www.belktile.com
BelkTile is offline   Reply With Quote
Issue With Mapei Ultracolor Grout MNTileGuy Professionals' Hangout 41 12-22-2012 10:27 AM
Where to buy Mapei Ultracolor? Kaki Tile Forum/Advice Board 7 09-05-2010 02:38 PM
help - new grout coming off (mapei ultracolor) sscheirey Tile Forum/Advice Board 3 08-12-2007 06:59 PM
New Mapei Ultracolor Plus Grout ? Kuma Tile Forum/Advice Board 2 05-23-2005 09:02 PM
