Unread 07-29-2013, 11:27 PM   #1
lasdj
Help!! New Porcelain Tile with Haze
My wife and I had someone help with our 300sq ft kitchen with grey porcelain matte tile (12x24). After applying the grout and removing the haze we noticed the haze was still there after drying. We didn't notice it much after the 2nd wiped down because they were sanded our ceiling (we had redone our entire ceiling and re-painted along with sand).
After all was completed they tried to remove the haze but its stuck there now. We tried mr clean which was maybe a bad idea, but it still didnt get rid of it. Then we went the route of using Bleach on our tiles on certain areas and it made it worse.
Then we went to Home Depot and bought 511 Sealer & Enhancement and tried it on a tile off to the side and it works well. It kept it shining and could not see the haze anymore. However after reading some more around the threads, I found out that I should not be using it.
So now my questions is:
1) How to remove the extra haze (we cleaned it almost 4 times around already)
2) Has the bleach ate through the tiles because its a little white? We tried sanding it and it helped but did not want to go that route.
3) When using the 511 sealer it works great, I like the dark wet color however I read it would not stay because this is porcelain tiles. Is there a way to give it the wet look (also with wet look, we will not see the haze, or the white streak that is probably left from the bleach as well).
Thanks and sorry for the long story. Let me know if you need any more details. Also the haze has been there for over 4 days already and we are all out of ideas.
John
Newbie
lasdj is offline   Reply With Quote
Unread 07-30-2013, 12:29 AM   #2
dhowardpeters
Overthinkin' wife of a caveman
I've read of success with Blaze and Lift-Off, but I believe always in reference to epoxy or Fusion Pro grouts. I'm sure a pro will be by shortly
Donna
dhowardpeters is offline   Reply With Quote
Unread 07-30-2013, 05:09 AM   #3
Davestone
Florida Tile & Stone Man
You should first remove the sealer with something like Aldon Premium Stripper,and some rags.
Then remove the grout haze with a grout haze remover,straight vinegar,or sulfamic acid crystals,and a stiff brush and wetvac.
http://www.aldonchem.com/section-products.htm
http://Davestonestile.com
Unread 07-30-2013, 06:58 AM   #4
doitright
doitright's Avatar
Hi John
1. Any of the products Dave suggested for grout haze removal (not the Aldon product).
2. The bleach only reacted with the grout haze, it did not eat through the tile. Do not continue sanding the tiles.
3. There are cases that the enhancer will work with porcelain tiles. If you choose to go that route, I strongly suggest you resolve getting the tiles clean first. After the tile & grout is completely dry you can consider doing another TEST area with the enhancer. I have had best success with Aqua Mix Enrich 'n Seal. All excess must be removed and tiles buffed before the enhancer dries on the surface. This holds true if a regular impregnating sealer is used as well.
John Koessler
Unread 07-30-2013, 10:39 AM   #5
lasdj
thanks everyone for your feedback. i feel so relieved, i thought i ruined it real bad. i will go the route of getting a grout haze remover.
is there any specific brand i should buy and any special technique i should use as well.
after cleaning the tiles hopefully i will be able to try a enhancer, my only concern is that would it wear off fast since its a matte porcelain tile? also would it become more slippery or slippery when wet (water spills)?
thanks!
John
Newbie
Grout Haze on Dark Porcelain Tile? hamie1 Cleaning, Restoration and Sealing 22 05-28-2014 11:05 AM
Spots / haze on linen look porcelain tile TexanMary Cleaning, Restoration and Sealing 3 04-02-2013 12:14 PM
Haze on Porcelain Tile KFINN59 Cleaning, Restoration and Sealing 3 06-14-2012 09:17 PM
grout haze over porcelain tile jerry1967 Tile Forum/Advice Board 1 04-21-2005 07:57 AM
porcelain Tile just laid. Help with haze Olaf Cleaning, Restoration and Sealing 2 02-23-2005 10:38 AM
