Unread 03-14-2009, 05:58 PM   #1
Dan Woods
Why not try
Kerdi membrane over concrete basement wall
I was wondering what is the best way to install the kerdi membrane over concrete basement wall. The wall is a little bumpy and not exactly even. I was wondering if I could use portland cement to install cement board directly to the wall and then install the kerdi. If not, any ideas would be greatly appreciated. Would it be better to skim coat the concrete walls to even them and then put the kerdi directly to the concrete wall?
Dan Woods is offline   Reply With Quote
Unread 03-14-2009, 06:33 PM   #2
jgleason
jgleason's Avatar
I think fastening furring strips to the wall and covering with a suitable substrate - drywall or CBU, then Kerdi would be better.
Unread 03-14-2009, 06:54 PM   #3
Dan Woods
Why not try
The only problem with that is that we already set the drain and adding furring strips would throw off the measurements for the drain. 2 walls are on concrete foundation walls. Do you think it would work if it's set on to conrete?
Unread 03-14-2009, 07:05 PM   #4
Lazarus
Lazarus's Avatar
If it's not too bad, you might consider "flash-patching" it with morter and going over that. Just a thought.
Unread 03-14-2009, 07:14 PM   #5
jgleason
jgleason's Avatar
Just how bumpy are we talking here? Skimming it out could work but I don't know enough to tell you exactly how that should be done.
Unread 03-14-2009, 07:14 PM   #6
crete51
old trowel man
crete51's Avatar
problen with sticken stuff to basement walls is makin sure it really bonds. forms used to pour concrete are almost alwys coated with oil to aloww easy removal when concret sets ...result nice smooth walls and a little oil residue left behind. wal needs to be cleaned ...acid etch or grind then bonding agent then skim coat then follow schluter requirements..been slingin pooky on concrete walls long time
Art
crete51 is offline   Reply With Quote
Unread 03-14-2009, 07:38 PM   #7
Dan Woods
Why not try
There is a concrete seam that sticks out a little. Could that be grinded down?
Other than that the walls are pretty even. The house is 50 years. I will definately use that acid to etch it. It wouldn't have to be evened to much. Thanks for the help.
Unread 03-14-2009, 07:41 PM   #8
I'd recommend grinding the ridge and scarifying the rest of the wall, Dan, and not the acid etching.
Unread 03-14-2009, 08:08 PM   #9
Dan Woods
Why not try
I'd be glad to but I'm not exactly sure what scarifying is.
Unread 03-14-2009, 08:19 PM   #10
Dan Woods
Why not try
I just bought the Joh Bridge book on kerdi. I could use all the help i can get. I really appreciate all the help from his site. I use it all the time. Thanks to everyone who replys on here. Even if I didn't post the questions I still get plenty of anwers.
Unread 03-14-2009, 08:59 PM   #11
Scarifyin' is just grindin' on it to make it clean and kinda roughed up, Dan.
Membrane over concrete w/o cracks pitterpat Professionals' Hangout 31 05-21-2008 10:15 PM
Ditra Membrane with Radiant Heat in Basement? peep Tile Forum/Advice Board 2 12-04-2007 09:50 AM
shower wall membrane? rayzor1234 Tile Forum/Advice Board 1 08-04-2006 09:17 AM
Shower wall membrane elCid72 Tile Forum/Advice Board 1 09-23-2004 02:06 PM
