Unread 01-05-2009, 08:11 PM   #1
briano96
briano96's Avatar
NOOB questions.
I'm planning on remodeling my rather small second floor bathroom. I've pulled up the old linoleum floor tiles and 3/4" plywood which had roofing felt on top of it. What I have left is 3/4" tongue and groove planking. There were tons of nails securing the plywood to the planking. The planking is in good shape, very solid.
Questions:
1. Should I screw the planking down to reduce deflection of the subfloor or is nailing okay?
2. I was thinking of using Ditra and Kerdi-Band in order to make a waterproof floor. Will I be able to apply the Ditra directly onto the planking or is some kind of backerboard required?
3. Or perhaps there is a better and/or easier method??? I am open to any and all suggestions as this is my first tile job. TIA.
briano96 is offline   Reply With Quote
Unread 01-05-2009, 08:33 PM   #2
ddmoit
ddmoit's Avatar
Welcome to the forum, Brian.
If any of it is loose, I would use screws to tighten it.
Before you put Ditra or a backerboard down, you will need at least a 3/8" of suitable plywood - 1/2" would be even better. Most folks don't feel the need to waterproof their floors, but Ditra with Kerdi-band would indeed be waterproof.
Dan - a DIYer in SE Tennessee
Unread 01-05-2009, 08:35 PM   #3
Welcome aboard, Brian.
You'll need plywood over the planking. The least you can get by with is 3/8, and 1/2 is better. Then the Ditra or 1/4 in. cement backer board. Yes, you can screw or nail the planks to the joists, but nail or screw the plywood into the planks only, not the joists.
Unread 01-05-2009, 09:07 PM   #4
briano96
briano96's Avatar
Thanks for the lightnin fast replies Men! I forgot to mention that the closet flange (toilet) is set to the height of the T&G planking. Whoever put down the 3/4" plywood cutout the footprint of the toilet from the plywood so that it was set on the planking while the linoleum tile was set up on the plywood. In other words the toilet was recessed into the floor????
I was also thinking of using Ditra because of how thin it is since I was concerned about setting the toilet on a "low" closet flange. I think I'll be able to solve that issue with a "Stack & Seal Flange Retainer Ring" which allows you to raise the height of the flange. The floor doesn't have to be waterproof but Ditra doesn't seem to be very expensive and it sounds easier than making a mudbed.
Just to be sure I've got it straight here's what I've got:
1.screw t&g planking into joists.
2.nail or screw 1/2" plywood into planking (not into joists).
3.apply Ditra to plywood using modified thinset.
4.use unmodified thinset to set tiles on the Ditra.
BTW, this job is gonna include tiling the walls and shower so I will probably be back with more very BASIC questions.
Unread 01-05-2009, 09:11 PM   #5
briano96
briano96's Avatar
Oh, BTW John, I ordered "Tile Your World" from Amazon the other day. I'm looking forward to getting my hands on it. Thanks.
Brian O
Unread 01-05-2009, 09:14 PM   #6
ddmoit
ddmoit's Avatar
I think you've got it, Brian.
Make sure the new plywood runs perpendicular to the joists.
Now that you have this thread going, bookmark it and come right back here with any additional questions on this project.
Unread 01-05-2009, 09:45 PM   #7
briano96
briano96's Avatar
Thanks Dan. I see your a Bears fan, me too. Born, raised, and still live in Chicago. Wait till next year!!!!
Unread 01-23-2009, 12:40 PM   #8
briano96
briano96's Avatar
Well I've removed the old 4"x4" wall tiles and patched and skim-coated the drywall. I've got 1/2" plywood to install on the 3/4" T&G subfloor on top of which I'll install Ditra and then the ceramic tile.
I've cut the plywood to fit the room, including cutting out a hole for the toilet flange. I've got a gap of about 3/8" to 1/2" between the plywood edges and the walls. Should I have cut the plywood so it was a "snug fit"? Can/should I fill the gaps with silicone, mortar, jif-set, grout?
Unread 01-23-2009, 12:54 PM   #9
Welcome, Brian.
You want to leave the gap around the perimeter of your subflooring. What you have is more than you need, but it's fine as is.
Hope that's in a dry area of your bathroom.
Unread 01-23-2009, 01:57 PM   #10
gardner
gardner's Avatar
non-professional opinion
Personally I've been trying for around 1/4 around the edge, but I wouldn't tear it out and start over because of that.
fill the gaps
In my recent project I used foam backer rod (intended for insulation) and it seemed to work fine.
- Gardner
gardner is offline   Reply With Quote
Unread 01-23-2009, 02:21 PM   #11
briano96
briano96's Avatar
"Hope that's in a dry area of your bathroom."
Yeah CX, the drywall that won't be covered by tile is outside of the shower enclosure and above the tile on the walls.
So you guys are saying that a gap is actually desirable? Damn, pure dumb luck!
Gardner, why did you fill your gaps with that foambacker rod?
Unread 01-24-2009, 09:31 AM   #12
briano96
briano96's Avatar
I'm thinking of installing a heatpad under the ceramic floor tile in my bathroom. Would I install it on top of the 1/8" Ditra using unmodified thinset or beneath it using modified thinset?
Unread 01-24-2009, 09:35 AM   #13
You would install the heating mat per the manufacturer's instructions. You would install the Ditra on top of the heat mat per Schluter's instructions.
The Ditra always wants to be on top of everything but your tile.
Unread 01-24-2009, 10:38 AM   #14
briano96
briano96's Avatar
Thanks CX
Unread 01-25-2009, 09:37 PM   #15
gardner
gardner's Avatar
why did you fill your gaps with that foam backer rod
It helps keep the gaps from accidentally getting filled with thinset or grout. A gap filled with cement doesn't do its job so well.
- Gardner
Bathroom Tile Project: Plan and Questions DumbUnusedID Tile Forum/Advice Board 9 09-18-2008 06:41 PM
noob questions and my bathroom thread vwfam Tile Forum/Advice Board 3 02-02-2008 08:00 AM
Old hearth out, finalizing plans, a few questions Dunadan Tile Forum/Advice Board 29 10-08-2007 05:14 PM
Transition between tile and laminate (and other newbie questions)? mknight Tile Forum/Advice Board 11 09-27-2003 11:57 AM
