[strike]Please forgive me for poor formatting/errors. Going on little sleep as I have been up very late to the wee hours of the morning finishing up the drywall work preparing for texturing before I hang the Durorock. BUT! The durorock can't be hung until this darn pan situation gets figured out.
So after they left, I checked the slope using a smart level and also a manual level.
Looking at the shower wall...plumbing and valve on your left, knee wall on your right.
There is 3/8" slope going to the drain at all areas, I checked every few inches.
Along the walls is level if you put a level parallel with the wall, flip the level towards the drain and there is 3/8" fall to the drain
For reference, I checked my other shower, it has 3/8" fall towards the drain with one spot that has 1/4" fall to the drain.
The pan is set and the intent is to use a method that I found here on the forums called a "Houston method". They did this with the mud bed and it cured quite well. However as previously noted, it has 1/8" fall towards the drain. I'm still half tempted to tear it all out and re-do it myself.
The pan has a slight lip above the slab to get the slope to the drain, the intent is to build up the existing slab to allow 1/4" fall towards the shower drain. My understanding is the intent is to coat the slab with redgard to seal it, float a bit of self leveler into the shower area and build up with thinset.
In regards to the pan liner....there seems to be a bit of Confusion. Im asking if it could be secured to the slab and folded over (see pics) but I"m being told it will be cut off, waterproofing membrane over the edge and then thinset/tile.
Another thing I noticed from reading the forum and digging the instructions for the pan/drain up..there should be pea gravel or finely broken tile around the drain for the weep holes. I think I can set the slope back myself so I may remove the 4:1, clean the weep holes and install 4" of pea gravel around the drain as indicated on the instructions.
I have done the entire bathroom myself up until this point. Completely overwhelmed and lacking confidence with the shower pan/waterproofing as I am terrified of a leak at this point. Maybe I'm overthinking things but all of this is new and I'm very green. Hired out the work and I'm even more worried now.
Anyways here are some photos.
Older photo, standing in the shower, looking at the entrance to the left where the fan is. This was the mud bed after it was put in and the fan blew on it all night. The slope will run from the wall back to the pan at a proposed 1/4"
Another view
Shower pan in and ready for the houston method
An in-progress pic
One more
Not really sure what I'm looking at but it looks to be ok having a 3/8" slope like my other shower. The corners were cut and folded using the oatley pan sealer stuff. I purchased the pan, it was a 6x10 if that matters.
This project is getting to me. I have mostly enjoyed it up until this point
Thank you all so kindly again for your priceless guidance.
