Old 07-17-2018, 05:25 PM   #16
One other thing that can promote cracking of tile is differential heating, often caused by a large expanse of windows. While many people avoid them like the plague, in-field expansion joints can help thermal expansion issues in a tile field if it is exposed to temperature swings. But, your cracks are probably due to slab issues, potentially normal. There are ways to isolate the tile from the slab through crack isolation materials, highly modified thinsets, or a combination of both.
Old 07-18-2018, 06:58 AM   #17
Lana, let us know how the meeting goes with the engineer. I bet he will advise getting soaker hoses and keeping the soil damp around your foundation.
Do you have any extra tiles?
Old 07-18-2018, 08:50 PM   #18
Triplelandj
Unfortunately the builder only left us 1 extra tile...and we must be over 2 dozen tiles at this point that have cracked.
Someone had mentioned in this thread to wait before re doing the floor because there will likely be more cracks. He was right....they keep coming. When do the cracks stop cracking? Is it when the foundation crack makes it to the other side of the house (assuming thatís whatís causing the tiles to crack). I keep hearing these ďbangsĒ and realize they are more splitting tiles! Itís so hard to be convinced the issue to be ďnormalĒ when the floor is splitting before my eyes.
Keeping my fingers crosssed that itís not a huge deal. It gets my blood pressure up every morning as I see the crack get longer and longer.
Yes, Iíll keep you posted. Weíre awaiting to get scheduled for the structural engineer. I imagine itíll be a couple weeks, as it seems to be a fairly slow process. Looking forward to some answers!
Thank you all for your advice and Knowledge!
Lana
Triplelandj is offline   Reply With Quote
Old 07-18-2018, 09:22 PM   #19
Most all slabs crack. IF the tile are not installed with that in mind, they'll crack, too. Note, if a crack has variations in height from side to side, you cannot retile things. Spreading cracks can be dealt with, but not elevation changes.
Old 08-09-2018, 06:18 PM   #20
Triplelandj
I just wanted to give an update, since it was requested.
The engineer came out today and took measurements (slab elevation) and compared them to when our house was built. There has been little to no movement. The dozens of tiles cracked because of the slab crack (like you all said) and the dry weather. Whew! Big relief! I think Iíll wait a while before redoing the floor, but When we do redo it, Iíll remember to make sure there is some sort of crack resistant barrier underneath the new flooring.
Thank you all for your help!
Lana
Not a good month Houston Remodeler The Mud Box 49 01-04-2015 08:28 PM
Help! 6 month old tile needs redo? / Need suggestions on underlayment Jeff1414 Tile Forum/Advice Board 17 06-12-2006 05:32 PM
Pic of the Month John Bridge The Mud Box 15 01-05-2002 04:12 PM
