Unread 11-02-2002, 07:23 PM   #151
RJ and Michaelene need to pony up mucho dinero.
Unread 11-02-2002, 07:37 PM   #152
rj
da Versa-tile Guy -- Official Keeper of the JB Forums Album
Si, Mucho Pesos Senoir..
mucho trabahjo too.....
If you have the proper tools and mindset......anything is possible !
rj is offline   Reply With Quote
Unread 11-02-2002, 09:55 PM   #153
J.L. Burns
Tile Contractor -- California
Send a message via AIM to J.L. Burns
Thanks for the advice- would you go one step further and tell them never ever consider doing a curbless shower?
J.L. Burns is offline   Reply With Quote
Unread 11-02-2002, 10:00 PM   #154
J.L. Burns
John with tongue in cheek I ask you, "how do you keep that kinda shower clean?" A concerned homeowner in a tingy voice
Jeff
Have Jackhammer will travel, I never told you it wasn't going to be dusty
Unread 11-03-2002, 06:49 AM   #155
The maid cleans this particular shower. I'll tell her what and what not to use before I leave.
Unread 11-03-2002, 07:14 AM   #156
John K
John.
Do you have another picture that shows the jambs, so we can see how you finished them off?
Did you backbutter the granite tiles?
On the shampoo niche. Did you bullnose the edges?
This thread lives on.
JK
John K is offline   Reply With Quote
Unread 11-03-2002, 07:17 AM   #157
tileguytodd
Official Felker Fanatic
tileguytodd's Avatar
Oh,i dont know,Ive done alot of curbless showers and done right they are fine.You really need to take a hard look at the mechanics though.
Handicap roll ins are becoming more and more desireable for many .With the advent of some of the new products (trowelable membranes etc) the mechanics arent even that critical anymore. I still like to drop the pan area though rather than build up outside room.Generally you only need to notch out a couple joists drop a length of 2x4 in full length.run 2x6 bridges across these at 16" OC and put down a good Plywood base.My absolute favorite method is to then do a standard pan liner run into the main room a foot.Pour an SLC in main room keeping back 16" from shower entrance.nail well a 1/4" CBU over 16" Area you left out in front with liner.(Nail it good) Coat it with Prored by C-Cure,let it dry.Feather area from SLC into the shower area with a good quality cementious fill. let dry.Now overcoat entire room up walls 2 inches and into shower pan area at least to drain.It wont leak,it cant leakand the entire room is protected from water dripping of wheel chairs or errant nurses spraying who knows what
Unread 11-03-2002, 07:50 AM   #158
J.L. Burns
Thank you so much Todd
Jeff
Unread 11-03-2002, 08:27 AM   #159
John K.
I've been criticized so much for the way I install vertical stone tiles I'm almost afraid to say it. Almost.
I "spot" the tiles up on a hard mud bed. When I float the walls I tend to tilt them out just slightly, maybe an eigth out of plumb. I can then install the bottom courses of tile very close to the substrate without worrying about my walls leaning in on me further up. I use the six-foot level to keep things running plumb and flat on the way up.
I get two courses all the way around the bottom to begin with. Maybe three courses. I make sure the whole base is level, straight and plumb, and then I leave it overnight. Now you have a very solid base that will support the weight of the tiles as they go up.
Spotting the tiles, placing four good globs of mud on the back of each, allows you to keep everything on absolute plane as you go. This business of having to have 100 percent coverage is bunk. I've been doing it this way for many years and have never had a problem with tiles cracking or breaking after the fact. It's different on a floor, of course.
The curb, seat top and jambs of this shower will be fabricated from granite slab by the stone fabricators I work with frequently. I have made doubly sure I've left them with straight walls to work to. I'll go back to take a picture or two.
We back mitered the tiles that surround the niche and back mitered the inside pieces to fit, leaving only the bevel on the front. It's a very tricky operation, ending up with a hole that is exactly the demensions of one tile. You have to caulk the inside joints, as there is nothing behind the pieces to catch the grout. It would just keep pushing through.
Here's how to get started:
Once I get things lined out all the way around the bottom of the walls, I have Albert make all the corner cuts, enough to go clear to the top. There is then no question that all the walls, including corners will be perfectly straight and plumb. It just can't come out any other way.
Unread 11-03-2002, 08:38 AM   #160
In this pic we've just finished grouting, and I'm ready to walk away from the shower.
Unread 11-03-2002, 09:04 AM   #161
davem
davem's Avatar
John, what's the story on that floor, did you make the little pieces from the big pieces? Is there any worry of it being slippery?
davem is offline   Reply With Quote
Unread 11-03-2002, 05:29 PM   #162
Ron
Tile Contractor
Wow.Nice granite shower,John.
My mortar is as dry as yours,I'm sure.I can walk on it right away if I have to.I just prefer the plastic trowel,especially on walls.The steel trowels make the mud bed too smooth for my liking,and none of mine are straight anymore.
Ron is offline   Reply With Quote
Unread 11-04-2002, 08:33 PM   #163
Dave, I lost the battle years ago on making the little pieces out of big pieces. When asked by my builder what I would charge to do it, I said $400 in an attempt to disuade him. He said okay, and he's been specifying them ever since.
Cut in 3-in. squares it's not as slippery as you might think -- just a bitch to maintain. But again, that's the maid's problem, I guess.
Ron,
I've never owned a plastic trowel. I might try one.
Unread 11-04-2002, 08:45 PM   #164
I've never seen a plastic trowel, 'cept those little bitty notched disposable thingees at the HD. Are we talking about a serious trowel? Is it thick plastic, like a magnesium or wood float? 'Splain me, please.
Unread 11-04-2002, 09:02 PM   #165
Bri
The Ditra Kid
Bri's Avatar
Hi
If you've seen the wall treatments that they are doing over extruded foam panels with modified acyrlic thin sets over top, you will notice the installers using plastic trowels to do the finish work. They are about 1/8 thick, and do a really nice job..but I'm not sure why.
BRIan
“The world is a tangled up necklace of pearls"
Bri is offline   Reply With Quote
mud work larrylou Professionals' Hangout 117 10-30-2011 02:33 PM
Where's that mud work how to thread? MGB Creative Tile Tile Forum/Advice Board 4 09-18-2008 05:26 PM
Mud work Rd Tile The Mud Box 2 04-16-2008 08:10 PM
Mud Work Charles P Professionals' Hangout 2 01-11-2008 07:33 PM
Methods for finding commercial work K_Tile Professionals' Hangout 23 10-31-2002 04:57 PM
