Unread 02-25-2022, 09:59 PM   #106
More often sparky than tile guy, Benjaminn, but I managed a bit of tile work, too. My real love was being the trim man, though.
But a forum mod? Unlikely.
Unread 02-27-2022, 03:38 PM   #107
tillytiles
If the recommended floor perimeter joint is supposed to be 1/4”, what should the joint between the floor tile and wall tile be? Also 1/4?
My drywall is undercut and so floor tile will have at least 1/4 if not more. But how close do you bring in the wall tile to the floor tile?
Benjaminn
tillytiles is offline   Reply With Quote
Unread 02-27-2022, 04:48 PM   #108
If your wall tile is above the floor tile, I'd leave one grout joint width or 1/8th of an inch, whichever is greater.
Unread 02-27-2022, 10:03 PM   #109
Snets
Professional Weekend Warrior
Snets's Avatar
Interesting. Glad none of my customers ever axed for those or I woulda been embarrassed, yes? 'Specially as I was the electrician of record on most all my new construction and remodel.
I replaced every outlet and switch in my house with Decora switches/outlets with screwless cover plates.....CX, you gotta get out more!
(Kitchen backsplash pictured here)
Unread 03-23-2022, 08:50 AM   #110
tillytiles
I am putting down 4x24 porcelain tile over ditra heat mat.
Locally, I have a choice between Laticrete 317 and Schluter All-set.
Do ya'll have a preference of either one of the mortars or just pick on and go with it?
Thanks.
Benjaminn
Unread 03-23-2022, 09:02 AM   #111
Either will work, Benjaminn
Unread 03-23-2022, 05:05 PM   #112
tillytiles
Thanks, CX. Floor layout question:
For the floor pictured, am I correct in this layout? Start with the center (“C”) and then have each of the outside perimeter tiles (arrows) cut to equal width for the area between tub and wall. Of would you lay it out in some different way? Thanks.
Benjaminn
Unread 03-23-2022, 05:18 PM   #113
No technical right and wrong with layouts, Benjaminn. The only "rule" in the tile industry standards says you should not have cuts smaller than half of a full tile. In today's world of larger and larger tiles, that becomes less and less reasonable to expect.
In your case, I'd hafta see the rest of the room to even guess, which I try not to do here at all. I have enough trouble deciding upon my own layouts even when I'm on site. A very large part of the process is making the layout look good to the customer, but making it look good to the installer is a good start.
What's in your photo is a single tile of your floor selection?
Unread 03-23-2022, 10:40 PM   #114
tillytiles
No those are individual 4x24 tiles. The room is simple - there’s a vanity alcove immediately to the left (bottom of the photo), then a straight run between the tub and right wall, then a toilet alcove on the right (top of photo)
Benjaminn
Unread 03-24-2022, 07:49 AM   #115
In that case you're not even making any less-than-half cuts, at least in the area we can see. Nothing wrong with that layout that I can see, so long as it looks good at the entry door and in other areas which we cannot see.
Unread 04-09-2022, 05:08 PM   #116
tillytiles
I have a small chip on the edge of my cast iron tub. I actually have the little piece that chipped. Maybe 1/4 inch. Anyone have good experience repairing this?
I know there's the diy epoxy filler kits and such with mixed reviews. I guess I'm wondering if there some reliable way I can glue or epoxy or something else this little chip I have back into its place? I was thinking maybe a marine epoxy or 3M 5200?
Benjaminn
Unread 04-10-2022, 07:56 PM   #117
That’s a tough one. I didn’t have good luck when Kohler hired a tub repair specialist for a damaged tub I had. The repair person is well known in these parts as being very good. But he left my job in frustration because his paints and chemicals have gotten more environmentally friendly and less adhesive than he needed.
As for gluing the chip back in place: if the chip is razor sharp at any portion of its perimeter, I would think you’d need to use a very low viscosity adhesive or the chip will stand proud of the surface and be a dangerously sharp hazard.
Unread 05-05-2022, 02:39 PM   #118
tillytiles
Thank you @Tool Guy - Kg !
Can you grout in sections or will that produce color variation/line? eg I want to grout under the vanity before it goes in obviously, but I want to wait to grout the rest of the floor until I'm done with everything else.
Benjaminn
Unread 05-06-2022, 06:38 AM   #119
You can, Benjaminn, but to ensure color consistency you'll need to carefully measure your grout and water. A digital kitchen scale is perfect.
Unless, of course, you intend to use a pre-mixed grout.
Unread 05-06-2022, 07:28 AM   #120
tillytiles
Thanks Dan. I plan on using Bostik’s TruColor urethane grout which is premixed so should work, I think.
Benjaminn
The five year bathroom redo Tulla Tile Forum/Advice Board 15 05-17-2010 09:04 AM
60 year old bathroom re-model Mirage2521 Tile Forum/Advice Board 36 03-07-2010 11:45 AM
140 year old bathroom floor stayathomemom Tile Forum/Advice Board 1 03-01-2009 09:53 AM
The TWO YEAR bathroom remodel DaveGordon Tile Forum/Advice Board 15 12-07-2008 10:35 AM
60 year old bathroom tile Unregistered Cleaning, Restoration and Sealing 2 01-30-2005 12:04 PM
