Old 07-12-2018, 02:41 PM   #1
Gnfanatic
Gnfanatic
Send a message via AIM to Gnfanatic
Can you provide some tips on my outdoor kitchen stone?
Hi guys, I just finished building my outdoor kitchen. It consists of 18GA steel 16"OC and 1/2" permabase cement board. I am getting real stone veneer delivered next week and would like to get ready for the install. My two questions is :
1-) before I put a layer of scratch coat on the boards do I have to use fibatape on the seams??
2-) I have several portland cement bags left, can I use them for the scratch coat? If so do I add sand??
Thank you guys!!
Any other tips are appreciated!!
Ralph
Ralph
Gnfanatic is offline   Reply With Quote
Old 07-12-2018, 05:25 PM   #2
Use alkali-resistant mesh tape on all the seams.
I think you'll want to add some sand to the portland for the scratch coat. Probably 3:1 sand to portland. I've seen some installers use a notched trowel to make the scratch coat, or you can put some on with a flat trowel and cut lines in it with a stick or something similar.
What kind of fasteners did you use to attach the cement board?
Old 07-12-2018, 05:27 PM   #3
Gnfanatic
Gnfanatic
Kman, thanks man. I just noticed I have Portland Type I/II, is that ok??
The store recommended Starborn cement board high-low screws?8x1 1/4. Was not fun screwing into 18GA metal studs
Ralph
Old 07-12-2018, 06:31 PM   #4
That Portland will work fine. You'll need to make wall mud for the scratch coat which would be 3 sand, 1 Portland and 1 lime. If that mix is too sticky, cut the lime down to 3/4. I would staple a layer of #15 felt paper and then screw lath to the board before scratching.
They make a rake just for scratching. I believe Home Depot has them in their concrete tool section. I have also used a small piece of lath to scratch with, about 5 inches square. The rake works best.
Old 07-12-2018, 06:45 PM   #5
Gnfanatic
Gnfanatic
Davy, why is felt needed on cement board?
Ralph
Old 07-12-2018, 06:52 PM   #6
Just to keep water out. Cement board isn't waterproof.
Here's a link to a scratch rake. https://demandproducts.com/OWA/Produ...ndle-scarifier
If you're going to use felt and lath, you could omit seaming the cement board.
Old 07-12-2018, 06:56 PM   #7
Gnfanatic
Gnfanatic
I appreciate the help guys are giving me. I will be doing the scratch coat this Saturday. I need to install the vents tomorrow and do plumbing. One thing that is bothering me is that I mounted this island directly to my pavers.I am wondering if I should have placed on top trex to keep it off the ground? The patio is pitched AWAY from the outdoor kitchen but I am worried about snow sitting there and melting.
Ralph
Old 07-12-2018, 07:02 PM   #8
What kind of countertops are you planning to have?
Old 07-12-2018, 07:03 PM   #9
Gnfanatic
Gnfanatic
I am probably going for granite.
Ralph
Old 07-12-2018, 07:10 PM   #10
When I mentioned the felt paper, I was thinking of keeping the water out of the inside. Sounds like water might be able to seep in under the stone and steel framing. Is that what you're thinking?
Old 07-12-2018, 07:12 PM   #11
Gnfanatic
Gnfanatic
Exactly. The steel is obviously galvanized but it sure is no T304 SS> So I am worried over time it might rot? Not to mention the edge of the cement board possibly rotting overtime from it always in contact with the pavers?
Ralph
Old 07-12-2018, 08:15 PM   #12
Doesn't sound like you're planning to build a roof over it. I'm sure building it on a concrete slab would have been better. Are the pavers going to give it a well supported surface? If it starts to shift and flex, I can see stone falling off. And, you know the granite won't like movement.
Old 07-12-2018, 10:00 PM   #13
Gnfanatic
Gnfanatic
I am sorry, did not explain it right. I actually poured a 6 inch slab of concrete for the base. It is mounted in front of the pavers. I should have explained it better.
Ralph
Old 07-14-2018, 10:53 AM   #14
Gnfanatic
Gnfanatic
Well guys. I cleaned the boards and then dampened it right before scratch coat.
3 sand, 1 type I/II and 1 lime. It sticks to the trowel but falls right off the board, will not stick for anything Possibly to much sand? Please help, thanks
Ralph
Old 07-14-2018, 12:16 PM   #15
That's the reason for the lath, Ralph.
Cultured Stone and Outdoor Kitchen KnotHead Tile Forum/Advice Board 7 04-08-2010 09:18 AM
Looking for tips on how to reinforce the subfloor for 18 x 18 stone JarekS Tile Forum/Advice Board 13 01-24-2008 08:11 AM
Tips on stone veneer on Cinder blocks? Kirk Grodske Professionals' Hangout 16 11-14-2007 08:22 PM
Tips For Grouting Square Edged Stone RexModeling Professionals' Hangout 18 03-30-2006 10:54 PM
Installing cultured stone fireplace, tips? Alastair Tile Forum/Advice Board 13 11-30-2004 03:28 AM
Found usc_block_11 empty, added this: [CODE] [/CODE]
