Old 07-07-2019, 03:59 PM   #1
Portrunner
Advice, Contractor grout too light
Hi, Just found this forum today. We hired a contractor to remodel the kitchen and put 1000 square feet of tile in. We picked Mapei Sahara Beige grout to blend the joints. Ultimately, we were left with varying shades of grout and haze all over the tiles. I contacted Mapei and they were very nice. They told me about cleaning the haze and also their grout refresher as we believe the grout was over washed or too much water was added to the mix. The contractor doesn't believe that the grout color was caused by his workers. We did mix the grout according to instructions to patch a grout hole and the color was perfect as displayed in one of the pictures. On top of everything the contractor painted the ceiling after having the floor installed and they left nice specks of white paint all over the tile. They tried to clean it but are now at the point where they believe I am too picky. I had an estimate from a company that specializes in grout to paint my grout and it was $2000. They state that the grout is flush in many places and needs to be ground down to create a channel for the paint/stain to adhere properly too. I am willing to pay for half of the grout to be repainted but am worried as I have read many places that a contractor is not required to do good work. The work is done but it is sloppy. I live in Florida if anyone is familiar with the laws. Any advice would be appreciated. Thank you. Rich
Rich
Portrunner is offline   Reply With Quote
Old 07-07-2019, 06:19 PM   #2
Elkski
Elkski's Avatar
Grout above the tile is sloppy by anyone's standards. Your not being to picky. Paint on the tile is not acceptable. It should clean off ok but on the grout not so easy. He should have mixed the different bags of grout together. Were the grout bags from the same n as tch? Good luck.
Teddy
Old 07-07-2019, 06:30 PM   #3
Portrunner
There was only one bag of grout. Mapei had me test the color of the grout by mixing a ratio of 3.5 to 1. The color came out perfect. I believe they added to much water to the mix and then possibly over washed it. There were pools of water on the tile when they were washing the grout off.
Rich
Old 07-08-2019, 03:34 PM   #4
Fast eddie part deux
You must be reading too much facebook. I believe the IBC does require contractors to install materials in a workman like manner. Which means to industry standards. I bet they used too much water in the grout so it would flow easily into the spaces.
Ed
Fast eddie part deux is offline   Reply With Quote
Old 07-08-2019, 04:31 PM   #5
Lazarus
Lazarus's Avatar
Yep. Too much water in the mix and/or overwetting the tiles during the wash....
Laz...
Old 07-08-2019, 05:22 PM   #6
Pour a little vinegar over a splotchy grout joint and let it sit there about 5 minutes. Then scrub it well with a scrub brush and rinse it with clean water. Let it dry and see if it looks any better.
Old 07-08-2019, 08:52 PM   #7
Portrunner
Thank you for all the advice. The contractor is going to pay for half of the grout painting. I am still a little worried as some of the grout comes out with my fingernail. The grout painting company does seem to be professional. They stated if there are problems with the grout they add grout and mix the new color into it. They did a sample under where my dishwasher will be and it came out good. The only negative is that the grout will not be flush and thus harder to clean as per him. Thanks
Rich
Old 07-09-2019, 06:32 AM   #8
The installed should pay 100% of the cist to make it right.
If the grout is removabke with your fingernail, it was mixed too wet. In regular concrete work, like a sidewalk, every gallon if water added to a cy of concrete reduces the ultimate strength by 100 psi. Same effect on your grout, which is a cementitious product.
If the grout painting company plans to add a skim coat of grout on top of the existing grout ... its going to be extremely thin. And are they proposing to do that after the painting doesnt work? Will the new grout stick to the paint?
Ed
Advice on contractor problem putter1 Tile Forum/Advice Board 25 07-15-2015 10:31 PM
New grout too light- acid wash or Mapei Grout Refresh?? BNR Cleaning, Restoration and Sealing 10 01-07-2014 08:22 PM
Advice on tile job by contractor jmessi Tile Forum/Advice Board 13 10-14-2012 12:35 PM
Need advice on bad tile job / contractor backspinnn Tile Forum/Advice Board 39 06-14-2010 05:47 AM
Contractor messed up, need advice on what to do. HELP!! sparq Tile Forum/Advice Board 21 08-24-2006 06:37 AM
