Old 07-02-2019, 07:36 AM   #16
Fast eddie part deux
Mike ... if are still buying tools ... this is a great opportunity to go to that much maligned source ... Harbor Freight ... and buy a cheap 1/2" slow speed drill to mix the slc.
Ed
Fast eddie part deux is offline   Reply With Quote
Old 07-02-2019, 01:08 PM   #17
Elkski
Elkski's Avatar
I was told to mix the SLC at high speed just don't en-train any air.??
ALso I read where the water is just right if a small bead of water forms at the vortex. I guess it means the particles all have a mating H2O. I got this every batch,.
Teddy
Old 07-02-2019, 07:14 PM   #18
Tiger Mountain Tile Inc
It can get a bit confusing. You install the levelers first if you are putting a membrane over them. However, if you want to use cement board then install that first- then use the levelers.
Jim Upton
DIYTileGuy
Old 08-07-2019, 03:02 PM   #19
Mike340
Just noticed your replies from July - sorry for the late response. Didn't get an email to let me know you responded. Anyway, thanks all for the advice.
Ed - I have a 1/2" drill on order from Harbor Freight and it should be here Friday.
I got wet feet about the SLC - it just isn't in my comfort zone, so I am using 1/4" Durock as a bonding layer for the tile and will use leveler over the CBU if required.
I plan on using the Durock brand screws to fasten down the CBU to the 3/4 T&G floor (with thinset over the plywood).
Are the Durock screws the best to use, especially on the 1/4 CBU? I have used these screws when I fastened the 1/2 CBU in the tub alcove and had to be very careful to minimize the cracking and crumbling. Read somewhere on the forum about someone using a different screw that was better. Any opinions on this? Any particular technique to avoid cracking along the edges (USG says the screws should be between 3/8 - 5/8 from the edge)
Thanks.
Mike340 is offline   Reply With Quote
Old 08-07-2019, 03:35 PM   #20
Lazarus
Lazarus's Avatar
Mike....make sure you embed the panels in thinset...mixed on the "loose" side just before you screw them down....
Laz...
Old 08-07-2019, 05:02 PM   #21
Mike340
Thanks Laz.
I plan to use Versabond polymer modified and will make sure to mix it somewhat loose.
Advice Needed: Tile Hearth Installation BillGriggs Tile Forum/Advice Board 2 09-18-2017 10:05 PM
Backsplash Grout and installation Issues-Advice Needed Nemr Tile Forum/Advice Board 1 03-21-2016 06:09 AM
URGENT - Mural installation advice needed lesliers Tile Forum/Advice Board 6 06-11-2010 04:19 PM
Preparing for new tile installation... advice needed. bigdonk Tile Forum/Advice Board 18 08-02-2009 05:57 PM
Shower installation advice needed Apexer Tile Forum/Advice Board 1 02-29-2008 10:17 AM
