Unread 05-08-2019, 03:35 PM   #1
madmax64
Madmax
Subway tile over exposed brick wall, how?
I would like to install subway tiles on the wall in my kitchen. There is an exposed brick wall (please see attached photograph).
I was thinking maybe I can apply thinset mortar over the brick. Let it dry then install subway tiles? If so, how do I make the wall FLAT before I install subway tiles?
Advice, suggestions, opinions, please?
Charles
madmax64 is offline   Reply With Quote
Unread 05-08-2019, 06:14 PM   #2
Gozo
How about putting CBU’s over the brick as a tiling substrate? My concern would be the total thickness of the CBU, mortar, and tile. Looks like you have maybe an inch or so to the back of the range, which would leave you kind of cramped.
Jeff
Unread 05-08-2019, 07:35 PM   #3
Are you sure these bricks are full size? We've installed a few brick backsplashes that were a thin veneer, maybe 1/2 - 3/4 thick. A picture taken of the end of the backsplash might help. Or does the brick cover the whole wall, even beyond the backsplash?
Unread 05-08-2019, 08:19 PM   #4
If that's a brick veneer, they sure did a clean job around the countertop, and it looks like the range hood above was set afterwards. My guess is, it's a brick wall.
If I'm right, then I would use a straight edge to identify any brick that are sitting proud of the rest of the wall. Those areas need to be chipped off with a hammer and chisel. Then I would use wet brick mortar to cover the whole wall and fill in the joints, sort of like a stucco job. Then you'd be ready for tile.
Unread 05-08-2019, 11:06 PM   #5
madmax64
Madmax
No, not brick veneer. These bricks are REAL. Check out the picture I just attached...
Ignore blue tape you see in the picture. I am painting the cabinets.
thanks
Charles
Unread 05-08-2019, 11:12 PM   #6
madmax64
Madmax
Kman, I like your idea. I might do that way. Brick mortar? Not sure if I can find "brick mortar" at Home Depot. Can I use regular mortar (not thinset)?
Charles
Unread 05-09-2019, 06:42 AM   #7
They'll have it.
Like this.
Unread 05-09-2019, 01:19 PM   #8
clifton clowers
I would check the age of those bricks. If they are old (pre-1920's or so) they are soft and portland cement based mortar, which is harder than the bricks, can cause the bricks to crack due to expansion and contraction issues. This is obviously a much bigger issue outdoors with freezing and thawing, but even here you can have chipping on the faces which can add up to an issue in time. If these are indeed old, a lime based mortar, which is softer than old brick, might make for a more stable substrate.
That said, I'd probably put up furring strips and mount backer board to that.
Clifton
clifton clowers is offline   Reply With Quote
Unread 05-09-2019, 08:56 PM   #9
Lou_MA
Wet shim some Kerdi board
Lou
Unread 05-09-2019, 09:56 PM   #10
CaliGrown
CaliGrown's Avatar
No need to complicate anything, do like Kevin suggested and it’ll be just right for tile. Leave yourself a soft joint at the counter and cabinets and there won’t be any issues down the line.
Christopher Machado 1 (916) 990-1751
Rest In Peace Joey Peres (7/16/95 - 8/31/19). A great friend and the best helper I’ve had.
Unread 05-10-2019, 12:25 PM   #11
madmax64
Madmax
My house was built in 1958. The brick wall (behind that stove is a fireplace in the family room) was built in around 1980's. So, the brick and mortar are still in good condition.
I will apply brick mortar (much like stucco work) to the brick wall, maybe sometime in June. Thank you for your advice and suggestions.
Charles
Unread 05-10-2019, 06:54 PM   #12
They look like Old Chicago Antique bricks, at least that's what they call them around here. They were real popular back in the 80's. Another vote for mudding it out. Embed a plumb screed stick in the mud on each end and use a straight edge to cut the mud.
Unread 05-14-2019, 06:58 AM   #13
Zoltan
I know this is anathema for this forum, but have you considered simply painting the bricks? They're already a durable surface and have great texture.
Zoltan
Zoltan is offline   Reply With Quote
Unread 05-14-2019, 07:58 AM   #14
Ah, yes! Paint it. Turn an interesting, but impossible to clean backsplash into a truly ugly backsplash that's impossible to clean. That's progress if ever I've seen it.
Exposed cuts, subway porcelain wall tile DownEastGC Professionals' Hangout 5 03-07-2019 09:30 AM
Subway Tile Outside Wall advice four32i Tile Forum/Advice Board 4 05-04-2017 11:39 AM
Sealing exposed brick interior wall? gellfex Cleaning, Restoration and Sealing 9 06-14-2011 09:49 PM
Tricky Exposed Brick in Shower: Need Opinions! jproney Tile Forum/Advice Board 2 09-09-2010 10:01 AM
Ending Subway Tile Mid-Wall jmhjr Tile Forum/Advice Board 5 07-29-2007 07:47 PM
